Car Brands
Car Manufacturers
Daihatsu
K3-VET YRV engine check light code
<blockquote data-quote="endy7527" data-source="post: 1063794381" data-attributes="member: 112081"><p>Update! Today i decided 2 ask my fren 2 test my sensor on his car, seems my sensor working good.. Last try, Reset all- disconnect -ve terminal of the batery, switch on the headlamp for 30nd n connect it back.. Start up the engine, YESS PROBLEMO SOLVED!! no more check engine light.. Hehe.. Now only the boost pressure problem left.. Thanks all...</p></blockquote><p></p>
[QUOTE="endy7527, post: 1063794381, member: 112081"] Update! Today i decided 2 ask my fren 2 test my sensor on his car, seems my sensor working good.. Last try, Reset all- disconnect -ve terminal of the batery, switch on the headlamp for 30nd n connect it back.. Start up the engine, YESS PROBLEMO SOLVED!! no more check engine light.. Hehe.. Now only the boost pressure problem left.. Thanks all... [/QUOTE]
david tao
Haltech E6X Sensors
Did e6x running well with TYT 1JZ or 2JZ Air sensor & O2 sensor for using on VR4 4g63T.
Urgently Required: Clutch for ER34 GT-t
Guys,
anyone out there know where i can get a new ER34 GT-t (RB25DET) clutch from? I need one rather urgently. Preferably a single plate.
Thanks
012-327-7655. Urgent
More Power From Your Exhaust
Just for our discussion...exhaust system in cars includes muffler to reflect the sound waves produced by the engine and reduce high pressure from internal combustion. Hence different capacity engine use different...
Car Brands
Car Manufacturers
Daihatsu
