Main Forums
Interests
ICE
JL subs... need help sifuz...
<blockquote data-quote="jeff_v2" data-source="post: 362922" data-attributes="member: 8355"><p>still looking for kicker cvr, anyone can help me????</p><p>bout the mono amp maybe go for </p><p>ROCKFORD FOSGATE PUNCH 301M MONO(1 CHANNEL) 900 WATT AMPLIFIER</p><p>spec:</p><p>Hook up a single 4-ohm subwoofer to Rockford Fosgate's Punch 301M mono amplifier for 150 watts RMS of MOSFET-fueled power. Better yet, string together two 4-ohm subwoofers, dial in a low-frequency boost (up to 12 dB at 45 Hz), and get ready for 300 watts RMS (at 2 ohms) of seat-shakin' bass voodoo! A variable low-pass crossover (50-250 Hz at 24 dB per octave) improves performance by blocking unwanted frequencies from your speakers. Your system won't just sound better, it'll operate more efficiently, too. Preamp outputs are part of the package, too - they'll let you add a second amp to your system, even if your receiver only has one set of preamp outputs. Heavy-duty power, ground, and speaker terminal connectors accept up to 8-gauge wire. </p><p></p><p>150 watts RMS x 1 at 4 ohms </p><p>300 watts RMS x 1 at 2 ohms </p><p>requires 10-gauge power and ground leads and a 30-amp fuse wiring and hardware not included with amplifier </p><p>selectable 50-250 Hz variable low-pass crossover, 12 dB per octave </p><p>TRANS"ana circuit designs keep voltages low and signal paths simple in the pre-amp section, for minimum distortion and maximum musicality </p><p>MEHSA provides more efficient transfer of heat from MOSFET output devices to the heatsink for cooler operation </p><p>TOPAZ noise-killing differential inputs that eliminate 80% of ground loop noise </p><p>NOMAD advanced protection circuitry for "intelligent" shutdown protection </p><p>preamp- and speaker-level inputs </p><p>selectable Punch Bass boost (0/6/12 dB at 45 Hz) </p><p>frequency response 20-20,000 Hz </p><p>11-1/8"W x 2-3/8"H x 9-7/8"D </p><p></p><p>so what u thing???? worth it or not</p><p>someone is selling 2nd hand also... what for feedback</p></blockquote><p></p>
[QUOTE="jeff_v2, post: 362922, member: 8355"] still looking for kicker cvr, anyone can help me???? bout the mono amp maybe go for ROCKFORD FOSGATE PUNCH 301M MONO(1 CHANNEL) 900 WATT AMPLIFIER spec: Hook up a single 4-ohm subwoofer to Rockford Fosgate's Punch 301M mono amplifier for 150 watts RMS of MOSFET-fueled power. Better yet, string together two 4-ohm subwoofers, dial in a low-frequency boost (up to 12 dB at 45 Hz), and get ready for 300 watts RMS (at 2 ohms) of seat-shakin' bass voodoo! A variable low-pass crossover (50-250 Hz at 24 dB per octave) improves performance by blocking unwanted frequencies from your speakers. Your system won't just sound better, it'll operate more efficiently, too. Preamp outputs are part of the package, too - they'll let you add a second amp to your system, even if your receiver only has one set of preamp outputs. Heavy-duty power, ground, and speaker terminal connectors accept up to 8-gauge wire. 150 watts RMS x 1 at 4 ohms 300 watts RMS x 1 at 2 ohms requires 10-gauge power and ground leads and a 30-amp fuse wiring and hardware not included with amplifier selectable 50-250 Hz variable low-pass crossover, 12 dB per octave TRANS"ana circuit designs keep voltages low and signal paths simple in the pre-amp section, for minimum distortion and maximum musicality MEHSA provides more efficient transfer of heat from MOSFET output devices to the heatsink for cooler operation TOPAZ noise-killing differential inputs that eliminate 80% of ground loop noise NOMAD advanced protection circuitry for "intelligent" shutdown protection preamp- and speaker-level inputs selectable Punch Bass boost (0/6/12 dB at 45 Hz) frequency response 20-20,000 Hz 11-1/8"W x 2-3/8"H x 9-7/8"D so what u thing???? worth it or not someone is selling 2nd hand also... what for feedback [/QUOTE]
david tao
toyo proxes R888 - 14" size?
hi guys,
jz wondering if R888 available for 14" ? (185/60/14)
i oni see lots of 15" being used, hmm..
any recommend on which shop selling it? or need to order at certain person/shop?
price range?
Super GT - Winner of GT300 Driver Title
Super GT - Winner of GT300 Driver Title goes to #101 Toy Story Racing apr MR-S
GT300 Driver Title winner comments
No. 101 TOY STORY Racing apr MR-S
Kazuya Ohshima: "We were able to win the title by...
DIY for Engine HeadCover
Engine HeadCover
Check this site out
http://www.geocities.com/r3dfire/DIY_engineheadcoverpaint.html
Its about painting the Engine's headcover.
I know this has been brought up before but I thought...
Main Forums
Interests
ICE
