Main Forums
Car Talk
Car Modification
Jasma hi-cams.
<blockquote data-quote="bera" data-source="post: 1064120422" data-attributes="member: 57493"><p>check the cam spec sheet first...particularly if there any increase in the lift...stock valve spring have limit of how much lift they can handle...if there a big jump in lift (let say from 7mm to 10mm lift) from stock cams...you might need to change the valve spring and all other related component for reliablity sake...</p></blockquote><p></p>
[QUOTE="bera, post: 1064120422, member: 57493"] check the cam spec sheet first...particularly if there any increase in the lift...stock valve spring have limit of how much lift they can handle...if there a big jump in lift (let say from 7mm to 10mm lift) from stock cams...you might need to change the valve spring and all other related component for reliablity sake... [/QUOTE]
david tao
diy a MegaSquirts V2.2 saga lmst, need help..
Hi all,
I'm planning to diy a MegaSquirts V2.2 to my saga lmst year 2004 to convert from carburetor to EFI system.The question is the throttle body,injectors,all the sensors,fuel pump,distributor,intake manifold...
Going back to SG this weekend..any guys wanna kirim anything...
Zex Nitous
Anyone knows where can find the Zex nitrous dealer?
Main Forums
Car Talk
Car Modification
Jasma hi-cams.
