Main Forums
General Talk
Is It Suitable...........
<blockquote data-quote="jeffayn" data-source="post: 907629" data-attributes="member: 2424"><p>The loud tapper sound create by most mits engine is because of the viscosities selection not because of the its mineral semi or fully.</p><p></p><p>However in the market most fully are grade with 5W 30/40/50. Those mits engine , if you use this viscosities, the tapper sound will be quite loud </p><p></p><p>However, if you use semi which is usually 10W xx / 15W xx. the tapper sound will be lesser then if you use the 20Wxx which in the market only introduce mineral. the tappered sound will be very minimal.</p><p></p><p>This happen ecause due the mits engine design, nothing is wrong with the engine oil or your engine it just the vis not being design to suit the 5Wxx .</p><p></p><p>But if you can get fully syn products but with the viscosity of 20Wxx or 15Wxx the tapper sound will be at minimal and you can enjoy the fully syn benefit too ...</p></blockquote><p></p>
[QUOTE="jeffayn, post: 907629, member: 2424"] The loud tapper sound create by most mits engine is because of the viscosities selection not because of the its mineral semi or fully. However in the market most fully are grade with 5W 30/40/50. Those mits engine , if you use this viscosities, the tapper sound will be quite loud However, if you use semi which is usually 10W xx / 15W xx. the tapper sound will be lesser then if you use the 20Wxx which in the market only introduce mineral. the tappered sound will be very minimal. This happen ecause due the mits engine design, nothing is wrong with the engine oil or your engine it just the vis not being design to suit the 5Wxx . But if you can get fully syn products but with the viscosity of 20Wxx or 15Wxx the tapper sound will be at minimal and you can enjoy the fully syn benefit too ... [/QUOTE]
R35 Used Titanium Exhaust
Toyo T1R
Where can i get toyo T1R? 195/55/15? at klang or other places that can get good price?
Drop Filter Question..
Hi Guys, this may be a silly question but just wondering. I have a K&N filter currently in my neo satria. I am purchasing a Altezza soon and just wondered if I could use the same filter for the Altezza? Is it the...
Offset rimmage
Okay, previously totally into modern lightweight design rims..but I'm liking the old skool style rims with noticeable lip (or magkuk)
However most of the old skool rims are only available in PCD 114
so my...
Main Forums
General Talk
