Main Forums
Interests
Do-It-Yourself Garage
is it safe? (open pod)
<blockquote data-quote="delphinium" data-source="post: 760685" data-attributes="member: 1332"><p>I used to have HKS power flow. So it happened that the sponge went reput liao so I changed temporarily to a normal sponge (very soft one), I think it is used for cuci pinggan one. That night I revved my car like crazy forgot about the sponge. Suddenly while happy revving, the car wont stop revving after I lifted the gas pedal. Then oni I remembered about the sponge. Quickly I put the gear to N and pulled over to the side of the road. PPl must have thought that I went crazy revving the car at 6k++ rpm while the car going oni at 10km/h and stopped eventually. Switched off the engine and took out the air-ram, and there ...... some sponge nicely squished at the bottom part of the butterfly opening at my throttle body. Lucky it didnt stuck inside the intake manifold. Took out the sponge and went home without sponge (now that's what I called OPEN pod) hehe.</p><p></p><p>The next day went to accesory shop and got myself an imitation power flow, took out the sponge and put it in my HKS. It worked fine all the way till I finally changed to an Apexi immitation air filter. No more headache about changing sponge liao.</p><p></p><p>Moral of the story: Use sponge accordingly! If it's meant for cuci pinggan then cuci pinggan it is for :)</p></blockquote><p></p>
[QUOTE="delphinium, post: 760685, member: 1332"] I used to have HKS power flow. So it happened that the sponge went reput liao so I changed temporarily to a normal sponge (very soft one), I think it is used for cuci pinggan one. That night I revved my car like crazy forgot about the sponge. Suddenly while happy revving, the car wont stop revving after I lifted the gas pedal. Then oni I remembered about the sponge. Quickly I put the gear to N and pulled over to the side of the road. PPl must have thought that I went crazy revving the car at 6k++ rpm while the car going oni at 10km/h and stopped eventually. Switched off the engine and took out the air-ram, and there ...... some sponge nicely squished at the bottom part of the butterfly opening at my throttle body. Lucky it didnt stuck inside the intake manifold. Took out the sponge and went home without sponge (now that's what I called OPEN pod) hehe. The next day went to accesory shop and got myself an imitation power flow, took out the sponge and put it in my HKS. It worked fine all the way till I finally changed to an Apexi immitation air filter. No more headache about changing sponge liao. Moral of the story: Use sponge accordingly! If it's meant for cuci pinggan then cuci pinggan it is for :) [/QUOTE]
R35 Used Titanium Exhaust
DIY or send it to some one? Wiring !!!
Hi all,
im looking to re wire my whole interior wiring since it is a 20 years old car.
should i do it my self since there are some company selling the wiring diy kit.
nahhh
do you know any good and reasonable...
Soon: No need for tyre pumps with AMT from Goodyear
Tired of maintaining your tyre pressure? Soon, there won't be a need to visit the...
Exhaust manifold on evo
Hi all,
I would like to know more about exhaust manifold on evo. What will be the result.?Better response in the beginning or more on high rev...?
Exhaust manifold installed. o2 housing connected to wastegate and a...
Main Forums
Interests
