Car Brands
Car Manufacturers
Honda
irritating problem
<blockquote data-quote="JEC6636" data-source="post: 1117358" data-attributes="member: 9618"><p>maybe you should check your throttle body there...i also had the same experience but mine was the throttle body problem..it's butterfly blade jammed a bit..so after serviced it then problem gone already...</p></blockquote><p></p>
[QUOTE="JEC6636, post: 1117358, member: 9618"] maybe you should check your throttle body there...i also had the same experience but mine was the throttle body problem..it's butterfly blade jammed a bit..so after serviced it then problem gone already... [/QUOTE]
R35 Used Titanium Exhaust
Looking for rear right caliper
Hello. I would like to ask if anybody have spare rear right caliper for sale?
Please contact me to the number 0133570526. Thank you.
Tomei stage 1 ecu for E7
call 012 2083222
20B 3Rotor
How much do you think for a 20B 3Rotor engine cost. Saw in an advert recently but haven't had time to call. It was a half-cut cosmo.
Is it legal to swap from 12A to 20B?
Cheers!
Car Brands
Car Manufacturers
Honda
irritating problem
