Car Brands
Car Manufacturers
Honda
Integra XSi 92-93
<blockquote data-quote="integramania" data-source="post: 517734" data-attributes="member: 334"><p></p></blockquote><p>i agreed... but e-manage will cost more $$$ la... can't plug n play like vafc... do u have any experience adding vafc...? i juz wondering la... why should we use racing chip if a/f could b controlled by vafc n so on...?yyyy...?[/QUOTE]</p><p></p><p><span style="font-family: 'Garamond'"><span style="font-size: 15px"><span style="color: blue">Hehe...yar lor expensive thing...yes i used to have a vafc...but again this thing only control AF and only limited points....but at least it can help lean it out or richen if needed....</span></span></span></p><p><span style="font-family: 'Garamond'"><span style="font-size: 15px"><span style="color: blue"></span></span></span></p><p><span style="font-family: 'Garamond'"><span style="font-size: 15px"><span style="color: blue">Well you can always just use a vafc on a stock chip...but what normally happens is ppl buy chip first cos its cheaper and then realise need to actually adjust the settings a bit so they get a vafc....in my view this is better lar....coz the chip also controls in ignition as well as speed cut, rev cut..etc....i also always wonder what is the difference between just rechipping then to get the original aftermarket ecu since it should be just the ecu doing all the major work...well I was told that the ICs inside the ecu is better than the stock etc. and does contribute.</span></span></span></p><p> <span style="font-family: 'Garamond'"><span style="font-size: 15px"></span></span></p><p><span style="font-family: 'Garamond'"><span style="font-size: 15px"><span style="font-family: 'Garamond'"><span style="font-size: 15px"><span style="color: #0000ff">Anyway bro I'm not an expert but if I had the $$$ I would use an aftermarket ecu with an e-manage</span></span></span></span></span></p><p>[/QUOTE]</p>
[QUOTE="integramania, post: 517734, member: 334"] [/quote] i agreed... but e-manage will cost more $$$ la... can't plug n play like vafc... do u have any experience adding vafc...? i juz wondering la... why should we use racing chip if a/f could b controlled by vafc n so on...?yyyy...?[/QUOTE] [font=Garamond][size=4][color=blue]Hehe...yar lor expensive thing...yes i used to have a vafc...but again this thing only control AF and only limited points....but at least it can help lean it out or richen if needed.... Well you can always just use a vafc on a stock chip...but what normally happens is ppl buy chip first cos its cheaper and then realise need to actually adjust the settings a bit so they get a vafc....in my view this is better lar....coz the chip also controls in ignition as well as speed cut, rev cut..etc....i also always wonder what is the difference between just rechipping then to get the original aftermarket ecu since it should be just the ecu doing all the major work...well I was told that the ICs inside the ecu is better than the stock etc. and does contribute.[/color] [font=Garamond][size=4][color=#0000ff][/color][/size][/font] [font=Garamond][size=4][color=#0000ff]Anyway bro I'm not an expert but if I had the $$$ I would use an aftermarket ecu with an e-manage[/color][/size][/font][/size][/font] [/QUOTE]
david tao
Looking For CK4A 4G92 Triptonic Part
Guys, need help..anyone got the CK4A 4G92 Triptonic complete engine mounting and complete original absorber, spring and mounting..tq
DIY: Toyota Camry Acoustic Damping
http://i1110.photobucket.com/albums/h444/jonlsl/Camry%20Acoustic%20Damping/P2070026800x600.jpg
Hey guys, I have an 05 Camry company car previously used by another person. So what I noticed was that when I closed the...
SAFC malfunction in 4G93
Recently installed SAFC in Wira 4G93 engine, but CheckEngine light turns on. RPM indicated only about half of the actual RPM meter reading, and no effect in A/F setting. Plug the whole SAFC to another car with 4G93...
Car Brands
Car Manufacturers
Honda
Integra XSi 92-93
