Main Forums
Car Talk
Car Modification
Intake manifold
<blockquote data-quote="boyzone" data-source="post: 882352" data-attributes="member: 10370"><p>normally, turbo engine throttle body will smaller compare with same version but NA engine, this due to NA need more air to generate power.</p><p></p><p>the long distand and small diameter route intake manifold is design for good torque reposen at low end, however , short and big diameter route will design for high end power output.</p><p>dun simply change / bore intake manifold, what ever u mod, need to match and study on our engine output bias first, is not, end up u will face lose power and not to gain the power. :D</p></blockquote><p></p>
[QUOTE="boyzone, post: 882352, member: 10370"] normally, turbo engine throttle body will smaller compare with same version but NA engine, this due to NA need more air to generate power. the long distand and small diameter route intake manifold is design for good torque reposen at low end, however , short and big diameter route will design for high end power output. dun simply change / bore intake manifold, what ever u mod, need to match and study on our engine output bias first, is not, end up u will face lose power and not to gain the power. :D [/QUOTE]
R35 Used Titanium Exhaust
S AFC2 need advise on adjustment
Sifu,
can anyone help me on my setting on 6a12tt. does the setting correct or need to do some adjustment?
Nissan Tiida/Latio S-tune PROTO by NISMO
http://img3.imagebanana.com/img/aete4oo1/tiidaproto1_1.jpg
The Tiida S-Tune PROTO concept featured a subtle bodykit that included front and rear aprons, spoilers and NISMO livery along with new alloy-wheels. NISMO...
oil in soark plug well..
oil in spark plug well (moved)
message deleted..
Main Forums
Car Talk
Car Modification
Intake manifold
