Main Forums
Car Talk
Forced Induction & Engine Management
Installing Mivec Block to my 4G91..
<blockquote data-quote="speed2horizon" data-source="post: 4452014" data-attributes="member: 30831"><p>There's no actual meaning of doing so... U can actually go for a 4G92 SOHC block, which cost less than half of MIVEC block. Still, U'll achieve 10:1 CR.</p><p></p><p>If u gonna use a MIVEC block, the 11:1 CR will require a larger injector to prevent premature detonation. If u were to upgrade, why not straight go for 4G93 SOHC block which cost the same as a MIVEC block. It's also plug n play. Just use back ur 4G92 oil pump. At least U'll get a 1.8 DOHC. Just my 2 cents suggestion.</p><p></p><p></p><p></p><p>Yes. 4G9X are all the same. Difference is only SOHC or DOHC. If u are replacing the whole short block.</p></blockquote><p></p>
[QUOTE="speed2horizon, post: 4452014, member: 30831"] There's no actual meaning of doing so... U can actually go for a 4G92 SOHC block, which cost less than half of MIVEC block. Still, U'll achieve 10:1 CR. If u gonna use a MIVEC block, the 11:1 CR will require a larger injector to prevent premature detonation. If u were to upgrade, why not straight go for 4G93 SOHC block which cost the same as a MIVEC block. It's also plug n play. Just use back ur 4G92 oil pump. At least U'll get a 1.8 DOHC. Just my 2 cents suggestion. Yes. 4G9X are all the same. Difference is only SOHC or DOHC. If u are replacing the whole short block. [/QUOTE]
david tao
ConverTTable your coffee table into the driving seat of your dreams
Driving games are just on another level when played with a steering wheel and pedal set but it isn’t always a plug and play affair with them. First you got to find a proper place to mount the steering and pedals so...
turbo suggestion
hi sifu-sifu,
for a 1054cc engine, targeting around 160-180whp, 7500rpm max, prefer boost to come before 3krpm.
what is the best turbine can get? rojak or original also can..
assuming money is not a major problem...
Ferrari F430 Scuderia Unofficial Preview
Apparently Ferrari couldn't wait to unveil the F430 Scuderia in Frankfurt; Instead Ferrari President Luca di Montezemolo was accompanied by F1...
Main Forums
Car Talk
