Main Forums
Interests
Do-It-Yourself Garage
install headlamp small bulb
<blockquote data-quote="12oY" data-source="post: 613713" data-attributes="member: 6621"><p>man at the right side of the lamp u have to take off the spare tank and u will c a small socket which contain small light bulb under the black rubber cover. just turn to loose the socket and pull out the bulb... if u replace with LED type.. put in the LED bulb andturn on light c got light up if no take out the bulb and install the other way round cause LED need positive and negative terminal... and at the left side light u san c it ..... good luck guys..</p></blockquote><p></p>
[QUOTE="12oY, post: 613713, member: 6621"] man at the right side of the lamp u have to take off the spare tank and u will c a small socket which contain small light bulb under the black rubber cover. just turn to loose the socket and pull out the bulb... if u replace with LED type.. put in the LED bulb andturn on light c got light up if no take out the bulb and install the other way round cause LED need positive and negative terminal... and at the left side light u san c it ..... good luck guys.. [/QUOTE]
david tao
Main Forums
Interests
