Main Forums
Interests
ICE
increase bass without adding subwoofer
<blockquote data-quote="mnkh0027" data-source="post: 3602588" data-attributes="member: 1674"><p>isobaric 6th order bandpass. it uses 2 drivers facing each other in a box.</p><p></p><p>Bump: </p><p>I extracted this from a diy project site. Since it's easy enough to understand, I'll just cut and paste to save time:</p><p></p><p><strong><u>Why Isobaric? </u></strong></p><p>I'm building a 6th order bandpass subwoofer here, they conventionally are arranged as follows: </p><p>[ATTACH=full]668715[/ATTACH] </p><p>However in an isobaric configuration the baffle has two speakers mounted on it, they are arranged face to face effectively forming an enclosure with a small cavity of air between the two drivers. </p><p>[ATTACH=full]668716[/ATTACH] </p><p>The drivers therefore must operate out of phase with each other <em>(or else they would cancel out each others motion)</em>.</p><p>In an isobaric configuration the layout is like this: </p><p>[ATTACH=full]668717[/ATTACH] </p><p></p><p><strong>Disadvantages</strong> </p><ul> <li data-xf-list-type="ul">The cost of drivers is doubled as you need 2 rather than 1.</li> <li data-xf-list-type="ul">Efficiency of the system is down by 3dB as compared to a single driver due to the added cone mass.</li> <li data-xf-list-type="ul">When you compare isobarics to a system which houses two drivers each in their own enclosure, this system would actually be 6dB less efficient.</li> </ul><p><strong>Advantages</strong> </p><ul> <li data-xf-list-type="ul">Distortion is reduced.</li> <li data-xf-list-type="ul">Sonic bass response is improved.</li> <li data-xf-list-type="ul">Bass is claimed as being tighter, faster, more accurate and more pure.</li> <li data-xf-list-type="ul">Best of all doing so halves the <em>Vas</em> of the driver, so the enclosure size required is halved also. <em>Meaning we can build a really small subwoofer. Being small is a great benefit, the sub won't take over your lounge or car boot which is a bonus!</em></li> <li data-xf-list-type="ul">Panel sizes are smaller, so it's easier to build a really sturdy box, i.e. one that is less likely to resonate.</li> </ul><p>So in a nutshell you would choose an isobaric configuration where: </p><ul> <li data-xf-list-type="ul">Size is a big issue.</li> <li data-xf-list-type="ul">When you want the box to be very small.</li> <li data-xf-list-type="ul">Where more accurate bass is important</li> <li data-xf-list-type="ul">And if you have a hefty amplifier with plenty of juice to spare.</li> </ul></blockquote><p></p>
[QUOTE="mnkh0027, post: 3602588, member: 1674"] isobaric 6th order bandpass. it uses 2 drivers facing each other in a box. Bump: I extracted this from a diy project site. Since it's easy enough to understand, I'll just cut and paste to save time: [B][U]Why Isobaric? [/U][/B] I'm building a 6th order bandpass subwoofer here, they conventionally are arranged as follows: [ATTACH=full]668715[/ATTACH] However in an isobaric configuration the baffle has two speakers mounted on it, they are arranged face to face effectively forming an enclosure with a small cavity of air between the two drivers. [ATTACH=full]668716[/ATTACH] The drivers therefore must operate out of phase with each other [I](or else they would cancel out each others motion)[/I]. In an isobaric configuration the layout is like this: [ATTACH=full]668717[/ATTACH] [B]Disadvantages[/B] [LIST] [*]The cost of drivers is doubled as you need 2 rather than 1. [*]Efficiency of the system is down by 3dB as compared to a single driver due to the added cone mass. [*]When you compare isobarics to a system which houses two drivers each in their own enclosure, this system would actually be 6dB less efficient. [/LIST][B]Advantages[/B] [LIST] [*]Distortion is reduced. [*]Sonic bass response is improved. [*]Bass is claimed as being tighter, faster, more accurate and more pure. [*]Best of all doing so halves the [I]Vas[/I] of the driver, so the enclosure size required is halved also. [I]Meaning we can build a really small subwoofer. Being small is a great benefit, the sub won't take over your lounge or car boot which is a bonus![/I] [*]Panel sizes are smaller, so it's easier to build a really sturdy box, i.e. one that is less likely to resonate. [/LIST]So in a nutshell you would choose an isobaric configuration where: [LIST] [*]Size is a big issue. [*]When you want the box to be very small. [*]Where more accurate bass is important [*]And if you have a hefty amplifier with plenty of juice to spare. [/LIST] [/QUOTE]
R35 Used Titanium Exhaust
How to tell a Coupe / Sedan from Skyline R32?
Hi all,
I'm helping a friend of mine getting some info for the Skyline GTR R32. All info is welcomed and deeply appreciated.
Q: How to tell a Nissan Skyline (the 32 version) is a Coupe or Sedan just...
safc 5 button : need help..
a few month ago i was bought the afc 5 button from one of forummer here...but till now i still not able yet to install it into my car..the problem is because i dont know the point from the harness(each color) to the...
WTA:rimm offset...
GUys,
Ccan 18x8.5 +22 fit in evo8 without rolling the fender.....anyone had tat one their ride??? any rubber rubbing ??? wht tires size ......
how bout 18x9.5 +22....possible???
THank.!
vr2turbo
Main Forums
Interests
ICE
