Main Forums
Car Talk
Car Modification
Ignition Wire Colour
<blockquote data-quote="cyclonite" data-source="post: 583764" data-attributes="member: 787"><p>There should be 5 wires in total mah...</p><p></p><p>1) +12V</p><p>2) ACC</p><p>3) ON</p><p>4) Ignition+Fuel pump</p><p>5) Start</p><p></p><p>The +12V should be completely black. Touch that against wires 1,2,3,4 and your car will work like normal. Touch it to number 5 to crank the starter. 5 should be black + yellow or black + red. Just try la because once you touch +12V against the 'start' wire the engine will crank already.</p><p></p><p>To drive the car you only need to touch +12V to the wire number 4. Of course you won't get dashboard lights, air cond, radio, etc.etc. but you can still drive away.</p></blockquote><p></p>
[QUOTE="cyclonite, post: 583764, member: 787"] There should be 5 wires in total mah... 1) +12V 2) ACC 3) ON 4) Ignition+Fuel pump 5) Start The +12V should be completely black. Touch that against wires 1,2,3,4 and your car will work like normal. Touch it to number 5 to crank the starter. 5 should be black + yellow or black + red. Just try la because once you touch +12V against the 'start' wire the engine will crank already. To drive the car you only need to touch +12V to the wire number 4. Of course you won't get dashboard lights, air cond, radio, etc.etc. but you can still drive away. [/QUOTE]
jeff6126
Honda Jazz FLRS side skirt
jeff6126
yellowcaliper /caliperspray
jeff6126
Te37 Track Edition 2 FK8 FL8 Civic Type R Rim Wheel...
Revozport R35 GT Wing Spoiler and Trunk
original rare Work Emotion 11R 18x8.5jj offset +47...
david tao
Spoon FK8 FL5 19 inch rim wheel Type R
Litchfield GTR R35 Road Suspension Kit Absorber
original rare Yokohama ADVAN Racing RG3 18x8.5jj...
david tao
~accident repair ~touch up paint
jeff6126
ZF Sales & Service Malaysia organizes Products Training for local car clubs
https://fbcdn-sphotos-f-a.akamaihd.net/hphotos-ak-ash4/s720x720/432161_303243473107069_133064996_n.jpg
The name ZF is unlikely to ring a bell for many people. However, ZF (also known as the ZF Group, or ZF...
all evo voltex widebody sifus plz look here and help me
i duno how many MM spacer should put to my car to make my voltex evo garang,please give me some comment,n how to make it wont hurt my bearing when i make my car tyres wide with spacer,thx
Step 0 vs Step 1 ECU
Hi guys,
Here's what happened.
"I just finished installed a 0450 SGTi rechip ECU into my friend Putra year 97 and we went for a test drive at MRR2
Result is awesome !! The car is much more powerful...
Main Forums
Car Talk
Car Modification
