Main Forums
Interests
ICE
ICE newbie needs help
<blockquote data-quote="spykey" data-source="post: 2245062" data-attributes="member: 45884"><p>1)</p><p>minimal requirement?ermm if u plan to get serious in SPL then i suggest u get a good amp or they usually ppl call it monoblock amplifier which is more practicable to blast a subwoofer.</p><p>but if u just wanna get ur rear trunk the sound of the subs and get drop ur rear mirror,low end amplifier also can.no prob!!keep in mind that low end amp like 1800watt is a bluff one.</p><p>mine is only 500w monoblok type;mrd501 coming fr alpine fortress but the blast of of subs was...gosshhhhh:)just my 2cents to share</p><p>2)</p><p>stock HU also enough but the features to play/adjust the sound tuning is limited laa..</p><p></p><p>cheers</p></blockquote><p></p>
[QUOTE="spykey, post: 2245062, member: 45884"] 1) minimal requirement?ermm if u plan to get serious in SPL then i suggest u get a good amp or they usually ppl call it monoblock amplifier which is more practicable to blast a subwoofer. but if u just wanna get ur rear trunk the sound of the subs and get drop ur rear mirror,low end amplifier also can.no prob!!keep in mind that low end amp like 1800watt is a bluff one. mine is only 500w monoblok type;mrd501 coming fr alpine fortress but the blast of of subs was...gosshhhhh:)just my 2cents to share 2) stock HU also enough but the features to play/adjust the sound tuning is limited laa.. cheers [/QUOTE]
Altezza vs Cefiro A31
How does it compare in terms of driving feeling? A31 is cheaper and made with 6 cylinders while older but Altezza is newer and better reliability. Both are RWD.
What material for HEAT SHIELD
eh guys here....i was wondering u guys was DIY heat shield.....what material u guys using?
like i wanna put something sticking underneath the bonet near the AIR FILTER area to prevent the hot BESI creating hot air...
diyturbo timer
any one had tried?
diy turbo timer using microware timer?
Main Forums
Interests
ICE
