Main Forums
Car Talk
Car Modification
IAT modification
<blockquote data-quote="revfast" data-source="post: 295574" data-attributes="member: 630"><p>Is anyone has try to install a resistor in the IAT receptacles, and it can 'default' the car is taking in air with a temperature of 0 celcius. </p><p></p><p>The timing is increased as much as 1.5 degrees.... But it has to reprogram the ECU, inorder to prevent over heating from the engine.</p><p></p><p>I been told from a fren it is really work. Amazing, just a resistor worth 10 cents can bring such a big improvement.... :o :o :o</p></blockquote><p></p>
[QUOTE="revfast, post: 295574, member: 630"] Is anyone has try to install a resistor in the IAT receptacles, and it can 'default' the car is taking in air with a temperature of 0 celcius. The timing is increased as much as 1.5 degrees.... But it has to reprogram the ECU, inorder to prevent over heating from the engine. I been told from a fren it is really work. Amazing, just a resistor worth 10 cents can bring such a big improvement.... :o :o :o [/QUOTE]
jeff6126
Honda Jazz FLRS side skirt
jeff6126
yellowcaliper /caliperspray
jeff6126
Te37 Track Edition 2 FK8 FL8 Civic Type R Rim Wheel...
Revozport R35 GT Wing Spoiler and Trunk
original rare Work Emotion 11R 18x8.5jj offset +47...
david tao
Spoon FK8 FL5 19 inch rim wheel Type R
Litchfield GTR R35 Road Suspension Kit Absorber
original rare Yokohama ADVAN Racing RG3 18x8.5jj...
david tao
~accident repair ~touch up paint
jeff6126
Melting Dashboard
Hi guys,
My year 2002 Altezza is fitted with the newer dashboard with sort of rubberished material. However over time and maybe due to our hot & humid weather, the rubberish surface have melted. Any members can...
NISMO Festival 2010
http://i483.photobucket.com/albums/rr194/mattynewera/nismo%20festival%202010/DSC_0932.jpghttp://i483.photobucket.com/albums/rr194/mattynewera/nismo%20festival%202010/DSC_0813.jpg...
WTT: My ChargeSpeed fender for ori fender
please refer to
http://www.zerotohundred.com/newfor...dlamp-and-chargespeed-fender.html#post2626104
Main Forums
Car Talk
Car Modification
IAT modification
