Car Brands
Car Manufacturers
Honda
HP gain from High Compression Pistons
<blockquote data-quote="J101" data-source="post: 1162873" data-attributes="member: 15660"><p>the standard way to determine your cylinder #3 is to do a leakdown test after compression test. if the results are no more than 20% it should be okay. if its more, then something is releasing air somewhere. bent valves? worn out rings? and etc.</p><p></p><p>i believe the tuners in sunway are already using the snap-on compression and leakdown test kit.</p></blockquote><p></p>
[QUOTE="J101, post: 1162873, member: 15660"] the standard way to determine your cylinder #3 is to do a leakdown test after compression test. if the results are no more than 20% it should be okay. if its more, then something is releasing air somewhere. bent valves? worn out rings? and etc. i believe the tuners in sunway are already using the snap-on compression and leakdown test kit. [/QUOTE]
david tao
Autocross in Feb
http://www.zerotohundred.com/newfor...belia-super-time-attack-challenge-2008-a.html
Get ur car ready guys.........hahahaha
WTS: used Evo 9 stock Intercooler
used
for sale
RM 850.00
pls refer to the attached pictures for reference
http://i167.photobucket.com/albums/u140/dukeracing/evointercooler.jpg
interested please...
Anyone Know This NISMO Strut Bar For What Car...PLS HELP!!
pls help..
can anyone tell me this nismo strut bar for wat car
[COLOR=blue ! important][FONT=verdana,geneva,lucida,"][COLOR=blue ...
Car Brands
Car Manufacturers
Honda
