Main Forums
Interests
Do-It-Yourself Garage
How to wire your Ice
<blockquote data-quote="Bert" data-source="post: 281662" data-attributes="member: 263"><p>g88,</p><p></p><p>both are correct depending on how the person wants to setup their system...</p><p></p><p>As for connection an X-box etc.. there may be 12V adapaters for the xbox which then you wont need to get a DC-AC converter. most of these converters go to 110V so u will still need to get a 110V adapter.</p><p></p><p>Also another important ting when wiring your ice is to disconnect your battery before starting. you dont want to cause any shorts right? And also double check your wiring before connecting back the battery.;</p></blockquote><p></p>
[QUOTE="Bert, post: 281662, member: 263"] g88, both are correct depending on how the person wants to setup their system... As for connection an X-box etc.. there may be 12V adapaters for the xbox which then you wont need to get a DC-AC converter. most of these converters go to 110V so u will still need to get a 110V adapter. Also another important ting when wiring your ice is to disconnect your battery before starting. you dont want to cause any shorts right? And also double check your wiring before connecting back the battery.; [/QUOTE]
david tao
WTB=ori bumper for my altezza
hi guyz..
finding and buying altezza ori bumper(sge) or altezza neo bumper.. pm me for price, location, hp number.. pic if possible.. thx
FS> R34 GTR / GT-t Veilside Lightweight Doors-NEW ARRIVAL!!!!
got a set of LH/RH R34 GTR/Gt-t Veilside Lightweight FRP doors with polyglass & GT type side mirrors.
just plug & play into R34 chasis.
pics...
advise on Brake oil change..
Thinking to change my brake DIY, undestand that the oil is drain out from the brake caliper at the tyre whereby there is a rubber nipple, and using a spana #8 to turn the screw to open the valve and let the oil come...
Main Forums
Interests
