Main Forums
Interests
ICE
How to Install a Car Amp
<blockquote data-quote="cacin" data-source="post: 414722" data-attributes="member: 10222"><p>here is the suggested fuse and wire size.</p><p>Please take note that this is only for one amp. If you plan to add and amp later, maybe you can use bigger wire from the battery to the distribution block. If you plan not to use distribution block, the wire size from the battery to the fuse and the fuse to the amp must be of the same size. Please also use same or larger size wire for ground connection. Please also take note that the suggested fuse is to protect the wire only. your amp should have it's own fuse to protect it. BTW, 50Amp is the max for 8AWG size wire. to be safe, maybe u can use 6AWG wire. Any more question, please feel free to ask.</p><p></p><p>http://www.bcae1.com/images/swfs/systemdesignassistant.swf</p><p></p><p>edit: due to image to big, please use the link above to calculate it on your own. Key in 300watt for the first amp. The rest put 0. cable length is up to you. voltage I think should be 12V. Amplifier is class AB and efficiency just put 50%. Then hit enter.</p><p></p><p>Wire Gauge :Recommended Maximum Fuse Size </p><p>00 awg : 400 amps </p><p>0 awg : 325 amps </p><p>1 awg : 250 amps </p><p>2 awg : 200 amps </p><p>4 awg : 125 amps </p><p>6 awg : 80 amps </p><p>8 awg : 50 amps </p><p>10 awg : 30 amps </p><p>12 awg : 20 amps </p><p>14 awg : 15 amps </p><p>16 awg : 7.5 amps </p><p>These are the recommended maximum fuse ratings for the corresponding wire size. Using a smaller fuse than what's recommended here will be perfectly safe. </p><p></p><p>Hope this helps.</p></blockquote><p></p>
[QUOTE="cacin, post: 414722, member: 10222"] here is the suggested fuse and wire size. Please take note that this is only for one amp. If you plan to add and amp later, maybe you can use bigger wire from the battery to the distribution block. If you plan not to use distribution block, the wire size from the battery to the fuse and the fuse to the amp must be of the same size. Please also use same or larger size wire for ground connection. Please also take note that the suggested fuse is to protect the wire only. your amp should have it's own fuse to protect it. BTW, 50Amp is the max for 8AWG size wire. to be safe, maybe u can use 6AWG wire. Any more question, please feel free to ask. http://www.bcae1.com/images/swfs/systemdesignassistant.swf edit: due to image to big, please use the link above to calculate it on your own. Key in 300watt for the first amp. The rest put 0. cable length is up to you. voltage I think should be 12V. Amplifier is class AB and efficiency just put 50%. Then hit enter. Wire Gauge :Recommended Maximum Fuse Size 00 awg : 400 amps 0 awg : 325 amps 1 awg : 250 amps 2 awg : 200 amps 4 awg : 125 amps 6 awg : 80 amps 8 awg : 50 amps 10 awg : 30 amps 12 awg : 20 amps 14 awg : 15 amps 16 awg : 7.5 amps These are the recommended maximum fuse ratings for the corresponding wire size. Using a smaller fuse than what's recommended here will be perfectly safe. Hope this helps. [/QUOTE]
david tao
SUMP for airtrek turbo
Hi GUYS
I hope you are all good.
I need a sump for my airtrek turbo
I tried to get one here in the UK and they sent the incorrect one. Please can any of you guys help me locate one or post the link for a sump where...
Auxiliary Injection
Hey guys,
I literally stumbled onto this thread over at rx7club.com. Check it out here:
Making The Case For The Powered FD: The Fix - RX7Club.com
Is there...
Turbo doesn't help my 0-100 Km/h (TD04 L15A)
if not wrong, stock (NA) Honda City should be 12 sec for 0-100 km/h.
Mine had turbo TD04 with AEM tunned , also 12 sec PLUS.
Time colleced by G-tech pro and RSM.
I had did alot of test on my car, ave timeing is 12...
Main Forums
Interests
ICE
