Main Forums
Car Talk
Forced Induction & Engine Management
How to drive car smoothly without MAP Sensor?
<blockquote data-quote="ecupro" data-source="post: 1518527" data-attributes="member: 20434"><p>Beyong_4896,</p><p>You quote :</p><p>"if by pass MAP sensor, then use Microtech ? In microtech edi got the boost sensor rite ?"</p><p></p><p>Bro,I am confuse here! You mean buy stand alone ecu, Microtech to replace the the map sensor ?</p><p></p><p>You quote :</p><p>"The boost sensor can replace the MAP sensor.?"</p><p></p><p>No, the ecu will get wrong reading, unless there is a "map calibration table" to change in that ecu.( if it is programmable one )</p></blockquote><p></p>
[QUOTE="ecupro, post: 1518527, member: 20434"] Beyong_4896, You quote : "if by pass MAP sensor, then use Microtech ? In microtech edi got the boost sensor rite ?" Bro,I am confuse here! You mean buy stand alone ecu, Microtech to replace the the map sensor ? You quote : "The boost sensor can replace the MAP sensor.?" No, the ecu will get wrong reading, unless there is a "map calibration table" to change in that ecu.( if it is programmable one ) [/QUOTE]
david tao
R33 Gts headlamp
RX7 550cc injector
hi anyone noe whr i can get RX7 550cc injector?how much would it cost?
D-I-Y turbo timer
I've heard somewhere that u can diy ur turbo time using timer from washing machine,etc.... can aah??? any ideas how???
Main Forums
Car Talk
