Main Forums
Interests
Do-It-Yourself Garage
How To Do Silencer For Loud Muffer?
<blockquote data-quote="WinDz" data-source="post: 484530" data-attributes="member: 2437"><p>did mine also .. same like joekers idea that jaywat said.. measure ur muffler tip diameter and get a stainless steel mug what can fit into ur muffler tip.. as for mine i used the 7cm diameter mug to DIY... those mug very cheap wan .. i bought mine 3 bucks.. remove the handle and drill hole on da mug. i dont have such a big drill bid therefore i drill a couple of holes instead of 1 big hole.. then i will have to drill a hole on ur exhaust tip there to screw the mug also .. otherwise when u travel ur car will shot that mug to the car behind u.. :P drilling the hole on the exhaust might be a lil bit tough if u DIY the drilling process.. the muffler's steel is damn hard, took me almost 30 minits to drill ... ~_~... or else u could send to those exhaust shop ask them to drill for u..</p><p>after installing, the effect of the muffler is having a quite almost like stock exhaust sound during idling.. normal driving still okie .. when u rev.. then the bassy sound will be there.. ^_^.. for testimonials on this DIY silencer u could pm and ask from these zth member, they sit inside da car and listen before " escaflowne" & "mindysy" &"chef_akina".. </p><p></p><p>http://img225.echo.cx/img225/3936/silencer9sz.jpg</p></blockquote><p></p>
[QUOTE="WinDz, post: 484530, member: 2437"] did mine also .. same like joekers idea that jaywat said.. measure ur muffler tip diameter and get a stainless steel mug what can fit into ur muffler tip.. as for mine i used the 7cm diameter mug to DIY... those mug very cheap wan .. i bought mine 3 bucks.. remove the handle and drill hole on da mug. i dont have such a big drill bid therefore i drill a couple of holes instead of 1 big hole.. then i will have to drill a hole on ur exhaust tip there to screw the mug also .. otherwise when u travel ur car will shot that mug to the car behind u.. :P drilling the hole on the exhaust might be a lil bit tough if u DIY the drilling process.. the muffler's steel is damn hard, took me almost 30 minits to drill ... ~_~... or else u could send to those exhaust shop ask them to drill for u.. after installing, the effect of the muffler is having a quite almost like stock exhaust sound during idling.. normal driving still okie .. when u rev.. then the bassy sound will be there.. ^_^.. for testimonials on this DIY silencer u could pm and ask from these zth member, they sit inside da car and listen before " escaflowne" & "mindysy" &"chef_akina".. http://img225.echo.cx/img225/3936/silencer9sz.jpg [/QUOTE]
david tao
DIY- Proton Gen 2 Rear Light Bulbs Replacement
Work: Change Rear Light Bulbs
Tool:
1. Philips Screwdriver - 1 unit
2.Multimeter - 1 unit
3. Replacement bulb - as required
Steps:
1. Open up your car boot.
2. Remove the 2 screw at the rear light using philips...
custom made race car
http://photos-665.friendster.com/e1/photos/56/68/52408665/1_960359707l.jpg
2010 Nissan 2.0L Class FR Sports Car
http://www.7tune.com/newtune/justin/nissanfr/header.jpg
Japanese automotive magazine Best Car fills us in on the latest news regarding Nissan’s FR Sports Car.
In retaliation to the rumours going around about...
Main Forums
Interests
