Main Forums
Car Talk
Car Modification
how to build a small cc, high revving engine?
<blockquote data-quote="SpeedWanker" data-source="post: 592365" data-attributes="member: 311"><p>IMO as u've said the limiting factor of u're engine is the push-rods..as far as i can remember check out some VW beetle tuners coz i think they might be able to custom titanium pushrods.. u'll also need higher rate valvesprings to keep the valves close at high speed, bigger valves to allow more charge in at high speed, longer duration cams, stronger and lighter con-rods, crank and pistons, higher pressure oil pump and preferbly running on a dry-sump set-up, higer rate fuel pump, more precise ingnition timing and fuel controller ie junking the carbs and distributor and the list goes on....</p><p>It would be great fun to build such an engine and kick asses but it would cost too much as malaysia has only limited resources and expertise when it comes to building high performance engines thats why most of us swap engines, its easier more reliable, cheaper and saves time..</p><p>sorry to let u down bro..</p></blockquote><p></p>
[QUOTE="SpeedWanker, post: 592365, member: 311"] IMO as u've said the limiting factor of u're engine is the push-rods..as far as i can remember check out some VW beetle tuners coz i think they might be able to custom titanium pushrods.. u'll also need higher rate valvesprings to keep the valves close at high speed, bigger valves to allow more charge in at high speed, longer duration cams, stronger and lighter con-rods, crank and pistons, higher pressure oil pump and preferbly running on a dry-sump set-up, higer rate fuel pump, more precise ingnition timing and fuel controller ie junking the carbs and distributor and the list goes on.... It would be great fun to build such an engine and kick asses but it would cost too much as malaysia has only limited resources and expertise when it comes to building high performance engines thats why most of us swap engines, its easier more reliable, cheaper and saves time.. sorry to let u down bro.. [/QUOTE]
david tao
195/45/r16 Tyre Fit Into 195/50/r16 Rim, Possible?
I was looking at this
Continental Tyres -ContiSportContact™ 3
and...
The Multi-Purpose Rescue Vehicle (MRV), a World’s First and Made in Malaysia!
https://www.zerotohundred.com/wp-content/uploads/2012/05/mrv_1.jpg
Natural disasters are pretty much inevitable. And since Malaysia gets quite a lot of rain throughout the year, natural disasters like flash floods...
Autocraft Performance - Microtech dealer in East Coast.
Hi all,
We are located in Maran, Pahang. Our aim is to cater the needs of motorsports ethusiast especially in East Coast of Malaysia (Pahang, Terengganu and Kelantan). Other region are most welcomed too. For a...
mysdolphin
Main Forums
Car Talk
Car Modification
