Main Forums
Car Talk
Forced Induction & Engine Management
How to boost higher ??
<blockquote data-quote="zaki" data-source="post: 610778" data-attributes="member: 1051"><p>1 bar? the simplest setup; get `tulang ikan' and adjustable fuel pressure regulator. do air fuel ratio tuning to adjust the pressure for FPR. </p><p>to fine tune you need at least 5 button AFC or SAFC and also do air fuel ratio/dyno tuning. no need engine management, no need bigger turbine, no need metal gasket (1 bar still can cope), no need to have EGT because it can't really tell you exactly whether you're running rich or lean. Once it is correctly tuned, the engine is safe to drive daily.</p><p>you don't have to buy bigger fuel pump UNLESS your fuel pump cannot support. You will know your fuel pump capability after you do air fuel ratio tuning/dyno. BUT you won't lose anything if you buy one.</p></blockquote><p></p>
[QUOTE="zaki, post: 610778, member: 1051"] 1 bar? the simplest setup; get `tulang ikan' and adjustable fuel pressure regulator. do air fuel ratio tuning to adjust the pressure for FPR. to fine tune you need at least 5 button AFC or SAFC and also do air fuel ratio/dyno tuning. no need engine management, no need bigger turbine, no need metal gasket (1 bar still can cope), no need to have EGT because it can't really tell you exactly whether you're running rich or lean. Once it is correctly tuned, the engine is safe to drive daily. you don't have to buy bigger fuel pump UNLESS your fuel pump cannot support. You will know your fuel pump capability after you do air fuel ratio tuning/dyno. BUT you won't lose anything if you buy one. [/QUOTE]
R35 Used Titanium Exhaust
WTS:aftermarket sidemirror for CT9A only..
Sold.........
[FS] S15 rear light
Good condition,no scratches.Good to keep as spare...
Price:
SOLD
Contact:016-2217111
http://i6.photobucket.com/albums/y239/bvalve/parts/S15rearlamp.jpg
Bangkok International Motorshow 2007 Thailand Cars and Girls. Part 1
[IMG alt="Bangkok Motorshow...
Main Forums
Car Talk
