Car Brands
Car Manufacturers
Honda
HONDATA ECUs? Where lah?
<blockquote data-quote="zaki" data-source="post: 2540167" data-attributes="member: 1051"><p>Long time no see...hehehe</p><p>yup, the PPP or BMEP depends on a lot of variables like rs ratio, bs ratio. theoretically we can determine the required ignition advance at every rpm at any engine load. but in the end, the final number won't be the same as calculated values.</p><p>i would like to ask you or anybody, do you dare to run extremely lean at WOT? something like 15-16....?</p></blockquote><p></p>
[QUOTE="zaki, post: 2540167, member: 1051"] Long time no see...hehehe yup, the PPP or BMEP depends on a lot of variables like rs ratio, bs ratio. theoretically we can determine the required ignition advance at every rpm at any engine load. but in the end, the final number won't be the same as calculated values. i would like to ask you or anybody, do you dare to run extremely lean at WOT? something like 15-16....? [/QUOTE]
david tao
Topless Porsche 991 let loose on Malaysian roads!
https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-ash3/s720x720/559092_587573673330_283900550_2314296_367290369_n.jpg
Back in Feb 2012, we reported the...
My DIY project with EliteHunter
Hola all ZTH members and forumers.
These are the DIY projects done by me and fellow ZTH member EliteHunter.
Special thanks to : unknown1x for the idea of CF spray.
We used 2 types of stensil , diamond shaped and box...
48 a/r specs needed
a friend of mine told me that there is a 48 a/r turbo from mitsu, if not mistaken is from mitsu eclipse, anyone here heard of it?
and there is also a 48 a/r from nissan, but i need to know more on the 48 a/r from mitsu.
Car Brands
Car Manufacturers
Honda
