Main Forums
General Talk
Honda roboboy...
<blockquote data-quote="BlackSamurai" data-source="post: 1037323" data-attributes="member: 4799"><p>that's the power of dream.</p><p></p><p>To create a 2 legs robot that can run is a new milestone in robot industry, a technology break through.</p><p>Because running involves more complex calculation + faster machine response.The momentum, leg movement, hand swinging and the central of gravity change every mili-seconds, the robot must have the processor that fast enought to do the accurate calculation to archive good balancing, not to mention the mechanical leg and arm need to give fast response (adjustment) based on the result of accurate calculation.</p></blockquote><p></p>
[QUOTE="BlackSamurai, post: 1037323, member: 4799"] that's the power of dream. To create a 2 legs robot that can run is a new milestone in robot industry, a technology break through. Because running involves more complex calculation + faster machine response.The momentum, leg movement, hand swinging and the central of gravity change every mili-seconds, the robot must have the processor that fast enought to do the accurate calculation to archive good balancing, not to mention the mechanical leg and arm need to give fast response (adjustment) based on the result of accurate calculation. [/QUOTE]
Tt @ 11/03
Anyone interested for a little TT this Friday night (11/3)?
FS: Apexi power fc E4,5,6
rm 1300. ecu only. no commander. L-Jetro
012 2083222
i have made a mistake earlier the ecu not for E7, but it can be use with some modification.
evo 7 need help
i cant boost over 1.5 bar why??? went it come close to 1.5 bar the car like kick hard from behind.
i had change the to powerfc
280 cam
fuel pump
no7 spark plug
evc5
is it the spark plug problem???? misfire
david tao
Main Forums
General Talk
Honda roboboy...
