Main Forums
General Talk
honda city PCD
<blockquote data-quote="bullet_nos" data-source="post: 4080022" data-attributes="member: 2748"><p>dun forget to check if the rims u r getting has a suitable offset too...cos i had to put spacers for mine up front as the inside of the rim will scrape the brake caliper without it...mine's a VTEC btw, the caliper is slightly bigger than the iDSi...</p></blockquote><p></p>
[QUOTE="bullet_nos, post: 4080022, member: 2748"] dun forget to check if the rims u r getting has a suitable offset too...cos i had to put spacers for mine up front as the inside of the rim will scrape the brake caliper without it...mine's a VTEC btw, the caliper is slightly bigger than the iDSi... [/QUOTE]
david tao
Proton Preve website is up!!
The official website is up! You won't be able to see the name to click on but you can swap the...
Questiom about sport rim
Question about sport rim
hi sifu,i need some info bout tis rim.
1)tis is 2 piece rim.wat brand for tis rim,bcos i cant found any name on it.i juz found 15" 6.5jj et30,made in japan,and some code i dont...
RiceBoy's Back With His Veilside Ride!!!
Guys, after a long moment of waiting and waiting ... finally it arrived from Japan, (sorry 'bout the blur images)
I was told that this is the last set that they are gonna produce :-( I...
Main Forums
General Talk
honda city PCD
