High Perfomance Sony XM-5540
ICE -In Car Entertainment
The Duke
High Perfomance Sony XM-5540 4 channel Sound Quality power amplifier.
SONY XM-5540 big and powerful beast legendary audiophile preference power amplifier with it's 4 channel 100watts X 4 @ 4ohm,/3 channel 100watts x2 + 200watts x 2 @ 4ohm/2 channel 200watts x 2 @4ohm, Ultra wide Frequency Response 8hz---100,000hz, Equipped with Chemical Capacitor with a capacity of 20,000uf for powerful reproduction of lower frequencies, High Stability High Voltage Pulse Power Supply Circuitry, Triple Protection Circuit, Wide Dynamic Range and extremely low distortion of less than 0.005%, Load impedance 2—8ohm, Two 30 amp fuse, Audiophile Grade NEC power Transistors (known for their very high quality), Separate /Isolated power supply circuit for low RF/Distortion. This huge and heavy power amplifier is “A Truly Magnificent Sound Quality Legend ”. Item in very good conditions inside out and never been repaired. This is the era before X-plod when Sony made top quality car audio similar to their high end Home Hi-Fi systems. Highly recommended for power hungry sound quality components speaker such as Morel, Dynaudio, Dls and Focal. Solidly Made in Japan. Conditions 8/10. .
NOTE:USED ITEMS FOR SALE HERE IS FULLY TESTED, IN PERFECT WORKING CONDITIONS AND 100% AUTHENTIC PRODUCTS FROM THE ABOVE STATED ORIGINS.
To purchase or inquiry please get in touch with JOHAN AIMAN HAKIM @ 017 2687014. Thank you Zerotohundred and thank you all.
