Main Forums
Car Talk
Car Modification
high cam setting
<blockquote data-quote="actuator_bypass" data-source="post: 3560402" data-attributes="member: 4976"><p>Basic adjusting, make sure your position of crankshaft is at Top Dead Center on the first piston.. but this is ketuk, ketuk tuning with aerospeed adjustable campulley. To be precise or just to get clearance of 0.001mm TDC then you have to use dial gauge as what JINKL as state up there.</p></blockquote><p></p>
[QUOTE="actuator_bypass, post: 3560402, member: 4976"] Basic adjusting, make sure your position of crankshaft is at Top Dead Center on the first piston.. but this is ketuk, ketuk tuning with aerospeed adjustable campulley. To be precise or just to get clearance of 0.001mm TDC then you have to use dial gauge as what JINKL as state up there. [/QUOTE]
Subaru Impreza GC8
R35 Used Titanium Exhaust
Video: Remembering the legendary Honda NSX
https://www.zerotohundred.com/wp-content/uploads/2010/07/Honda-NSX.jpg
The year is 1990 and the world saw the birth of possibly the greatest Japanese supercar of all time, the Honda NSX. Developed painstakingly over...
OHLINS Suspension Kit
Any of you Taikos here heard of OHLINS Suspension Kit before for Tezza? Heard is the best money can buy coilovers for Tezza, they claim it is even better than TOM'S Advox...i've managed to check online but very few...
Gt2871
sOMETHing TO sHARE
Compressor Map GT2871R
cONStant Parameter in Calculation
BSFC = 0.55
Manifold Temp , Tm= 130 F
Gas...
Main Forums
Car Talk
Car Modification
high cam setting
