Car Brands
Car Manufacturers
Mitsubishi
hi ppl...need help...pleeeeeeeeeeaaassseeee
<blockquote data-quote="HyperRevved 6313" data-source="post: 740459" data-attributes="member: 12056"><p>Oh i also has this problem with my engine before :D Check your FICD . Try to change to another one that hav smooth idiling . Check your throtte also . It might dirty and cause ur air intake goes in not smoothly.</p></blockquote><p></p>
[QUOTE="HyperRevved 6313, post: 740459, member: 12056"] Oh i also has this problem with my engine before :D Check your FICD . Try to change to another one that hav smooth idiling . Check your throtte also . It might dirty and cause ur air intake goes in not smoothly. [/QUOTE]
Hear the Aston Martin Zagato V12 growl
https://www.zerotohundred.com/wp-content/uploads/2011/05/zagatov12.jpg
Autoblog of Netherlands managed to record the video of the V12 growl coming from the Zagato designed Aston Martin. Zagato has been designing...
engine monitoring
bros,
has anybody seen a device that can monitor
oil pres,
oil temp,
water temp,
volt, amps,
vacuum
in 1 package?
buying gauges for each is quite expensive, also worry about idiots stealing.
your input much...
DIY - decals -
did these decals using normal stickers bought from 'brother's'
first i draw the needed logo in my computer..
then i mirror image the logo...
then print it to the required size at the back of the sticker sheet...
then...
Car Brands
Car Manufacturers
Mitsubishi
