Car Clubs
Car Club Categories
The MR2 MRS Club
Help
<blockquote data-quote="koolspyda" data-source="post: 2799604" data-attributes="member: 2832"><p>normal oil service should be a problem. others... may need shop with prior experience on SMT. bangsar TOMS or SG besi shop.</p><p></p><p><span style="color: Blue">Problems:</span></p><p><span style="color: Blue">1. When I turn my steering to maximum left / right, it make a clak clak sound. I took to the workshop, he say is the drive shaft problem, but when he check he say the car dun have drive shaft and he is too busy to layan me. =(</span></p><p></p><p>either your <strong>suspension mounts</strong> or the <strong>endlinks bushings</strong>. check them first.usually are the culprits (90%). remember the MR-S has a LOT less insulation compared to the SW20 & being an open top hence sounds are typically more audible compared to a coupe or hard top.</p><p></p><p><span style="color: Blue">2. My SMT gear also producing some sound</span></p><p>not clear. can you engage still? wear & tear on the pump. require a pump oil change? USE CORRECT SMT OIL. several shops farked the SMT with WRONG SMT OIL. SMT pump OIL is not the same as the SMT gearbox OIL. </p><p></p><p><span style="color: Blue">3. My absorber / spring is giving me a very bumpy ride + a lot of squat and dive</span> </p><p>leak suspension?? check them. usually when time is up (leak) one will experience spongy ride. also</p></blockquote><p></p>
[QUOTE="koolspyda, post: 2799604, member: 2832"] normal oil service should be a problem. others... may need shop with prior experience on SMT. bangsar TOMS or SG besi shop. [COLOR="Blue"]Problems: 1. When I turn my steering to maximum left / right, it make a clak clak sound. I took to the workshop, he say is the drive shaft problem, but when he check he say the car dun have drive shaft and he is too busy to layan me. =([/COLOR] either your [b]suspension mounts[/b] or the [b]endlinks bushings[/b]. check them first.usually are the culprits (90%). remember the MR-S has a LOT less insulation compared to the SW20 & being an open top hence sounds are typically more audible compared to a coupe or hard top. [COLOR="Blue"]2. My SMT gear also producing some sound[/COLOR] not clear. can you engage still? wear & tear on the pump. require a pump oil change? USE CORRECT SMT OIL. several shops farked the SMT with WRONG SMT OIL. SMT pump OIL is not the same as the SMT gearbox OIL. [COLOR="Blue"]3. My absorber / spring is giving me a very bumpy ride + a lot of squat and dive[/COLOR] leak suspension?? check them. usually when time is up (leak) one will experience spongy ride. also [/QUOTE]
jeff6126
Honda Jazz FLRS side skirt
jeff6126
yellowcaliper /caliperspray
jeff6126
Te37 Track Edition 2 FK8 FL8 Civic Type R Rim Wheel...
Revozport R35 GT Wing Spoiler and Trunk
original rare Work Emotion 11R 18x8.5jj offset +47...
david tao
Spoon FK8 FL5 19 inch rim wheel Type R
Litchfield GTR R35 Road Suspension Kit Absorber
original rare Yokohama ADVAN Racing RG3 18x8.5jj...
david tao
~accident repair ~touch up paint
jeff6126
Buying an R33 Sedan
Dear sifus,
My cousin study in Japan and plans to return home by this June. Last year he purchased a R33 skyline sedan with a RB20E turbo. He insisted to bring over here in Malaysia. The question is;
1) Is the...
DIY 12V Battery Desulfator
Came across this article from Elektor Electronics Magazine - November 2004 on the project for building a car battery desulfator.
http://notes.ump.edu.my/fkee/e-Magazine/Elektor%202004/Articles/E/e04b020.pdf
Extract...
Top Secret V35 'GTR' creates new street record
Top Secret TAS V35 'GTR' has just created a street record of 341km/h at Autobahn.
Read more.
http://www.topsecretjpn.com/home.shtml
Btw, this car is equipped with a fully rebuilt VK45 V8, Twin Turbo and ATTESA. It...
Car Clubs
Car Club Categories
The MR2 MRS Club
Help
