Main Forums
Car Talk
Car Modification
help this diagram
<blockquote data-quote="jinkl" data-source="post: 2523389" data-attributes="member: 3008"><p>aiyak sorry i dnt understand your english</p><p></p><p>yes if u buy 1bar wastegate, then 1bar it will open</p><p>if u want to boost higher than 1bar then only u fix the top hose for bleed valve</p></blockquote><p></p>
[QUOTE="jinkl, post: 2523389, member: 3008"] aiyak sorry i dnt understand your english yes if u buy 1bar wastegate, then 1bar it will open if u want to boost higher than 1bar then only u fix the top hose for bleed valve [/QUOTE]
david tao
The Porsche Taycan Turbo S arrives Malaysia! + Turbo & 4S
Porsche's full electric Taycan arrives Malaysia! Debuted right here at the new Porsche Centre Ara...
DIY modify & installing Oil Catch Tank upgrade version
Here I would like to share how you could modify and hook up your oil catch tank and make your catch tank work more efficient. But 1st a small class session.
Q: Why need oil catch tank?
A: The oil catch tank is a...
Auto Altezza - have LSD or not?
was reading this from the LOC.........
A01A - 3.916 ratio Open Centre
A01B - 3.916 ratio Torsen LSD
A02A - 4.083 ratio Open Centre
A02B - 4.083 ratio Torsen LSD
So the 'B' denotes LSD...
Main Forums
Car Talk
Car Modification
help this diagram
