Car Clubs
Car Club Categories
Mitsubishi Lancer Owners Club
[HELP]...Radiator recommendation
<blockquote data-quote="kampoon" data-source="post: 1064067424" data-attributes="member: 24196"><p>replaced your faulty thermostat to the low temp thermostat is not recommended because today's computerized engine control systems require a constant operating temperature of about 8x degrees C for Mitsu Engine if i am not mistaken.. The engine's emission controls as well as it's fuel and spark control systems are all calibrated to work within a given temperature range. If someone replaced the thermostat with the wrong one for the application (either colder or hotter), it can cause driveability, fuel economy, performance and emissions problems. So if the thermostat is replaced for any reason, it must be replaced with one that has the same (or correct) temperature rating for your vehicle. </p><p></p><p>My new 2 Cents.....Hope this will help....</p></blockquote><p></p>
[QUOTE="kampoon, post: 1064067424, member: 24196"] replaced your faulty thermostat to the low temp thermostat is not recommended because today's computerized engine control systems require a constant operating temperature of about 8x degrees C for Mitsu Engine if i am not mistaken.. The engine's emission controls as well as it's fuel and spark control systems are all calibrated to work within a given temperature range. If someone replaced the thermostat with the wrong one for the application (either colder or hotter), it can cause driveability, fuel economy, performance and emissions problems. So if the thermostat is replaced for any reason, it must be replaced with one that has the same (or correct) temperature rating for your vehicle. My new 2 Cents.....Hope this will help.... [/QUOTE]
Subaru Impreza GC8
R35 Used Titanium Exhaust
Honda CR-Z Gets CVT and 7-Speed Paddle Shifters!
Ever since the November 2011 launch of the Honda CR-Z hybrid in Malaysia, it has garnered a tremendous amount...
How to remove PV6 front bumper?
Hi all, i'm planning on to retrofit my Perdana V6 headlamps but it seems that I need to remove my bumper to get the headlights out...anyone here familiar with removing a PV6 bumper? Thanks...:wavey:
DIY boost meter installation
scince nobody read the thread i post under existing topic, well then i post it again under new topic..:Not_Impressed:
please if anybody know how to install boost meter into Mira L2 engine..where should i connect the...
Car Clubs
Car Club Categories
