Main Forums
Car Talk
Forced Induction & Engine Management
Help on boost
<blockquote data-quote="SDF" data-source="post: 106700" data-attributes="member: 546"><p>cud be a case of actuator accidentally bent during installation...therefore giving higher boost...</p><p></p><p>but as Master Foo said....usually on 4th n 5th u'd get higher boost readings...then it'd drop back to norm levels...</p></blockquote><p></p>
[QUOTE="SDF, post: 106700, member: 546"] cud be a case of actuator accidentally bent during installation...therefore giving higher boost... but as Master Foo said....usually on 4th n 5th u'd get higher boost readings...then it'd drop back to norm levels... [/QUOTE]
R35 Used Titanium Exhaust
Leaking T-Bar!
Hi All,
It rained exceptionally heavy today and normally, my roof won't leak so much, only maybe a drop or two from the joint nearer the front. But today, it literally poured water into the cabin. The leak was from...
can emanage throw away AFM
guys i wonder... can emanage get rid of afm like microtech lt10s and haltech?
coz im planning to get emanage very soon...
thanks...
Ideal GZE piping size
Hi, may i ask what is the best piping size for 4agze (ae92 '91)?
is it 2inch since it's almost like na when the sc is off or should it be bigger, more like turbo style (3inch)?
i'm aiming for a balance between...
Main Forums
Car Talk
Help on boost
