Main Forums
Interests
Motorsport Specifics
Drifting
Help Need
<blockquote data-quote=".S K A G E E." data-source="post: 485749" data-attributes="member: 2299"><p>err.. I think this question has been posted before..but to answer your question; there are 4 pieces of equipment that you'll need to be able to drift</p><p></p><p>1) LSD.. No matter what some might argue I feel that LSD is essential when it comes to drifting..</p><p></p><p>2)Suspension.another must have item..you need them to be fairly stiff..so a track like shocks are required</p><p></p><p>3) Adjustable set up..ie Chamber , toe, you need to set them up to be able to drift properly.</p><p></p><p>4)Decent power.. you need a certain amount of power to be able to pull the car out of a drift.</p><p></p><p>After drawing out the four basic necessities of a drift car..see if the car that you are looking at has all of these available.&if they are then that will be the right car for you</p></blockquote><p></p>
[QUOTE=".S K A G E E., post: 485749, member: 2299"] err.. I think this question has been posted before..but to answer your question; there are 4 pieces of equipment that you'll need to be able to drift 1) LSD.. No matter what some might argue I feel that LSD is essential when it comes to drifting.. 2)Suspension.another must have item..you need them to be fairly stiff..so a track like shocks are required 3) Adjustable set up..ie Chamber , toe, you need to set them up to be able to drift properly. 4)Decent power.. you need a certain amount of power to be able to pull the car out of a drift. After drawing out the four basic necessities of a drift car..see if the car that you are looking at has all of these available.&if they are then that will be the right car for you [/QUOTE]
R35 Used Titanium Exhaust
Mitsubishi evolution 7
Dear Sifu's,
I require some information:
Would it cause any sort of problems if I jump-start my EVO7 ? Will it effect the ECU or any components of the car.
Please feel free to share thoughts in this regard...
looking for altezza GPS enclosure.
Hi..as per title, im looking for the GPS enclosure for trade or swap with me (mine is the flat one)...
horn driver for alarm?
idea to use a horn driver as siren for car alarm
this way the thief will get a shock !!
anyone know where i can get one, want to use for experiment
20-50W second hand or new as cheep as possible.
Main Forums
Interests
Drifting
Help Need
