Car Brands
Car Manufacturers
Nissan
help my N13
<blockquote data-quote="WBW7827" data-source="post: 657486" data-attributes="member: 14685"><p>u can go to jalan kapar to find lots2 of ga16de efi..dunno auto or manual transmission..</p><p>about ur sudden accel press when switch on aircond then engine just died;</p><p>i think somethin to do with vacum, or air fuel mix not tuned well..try tanya ur mechanic..</p><p>about black smoke;</p><p>maybe ur piston rings dah worn out and air fuel mix again..</p><p>about hi fuel consumption;</p><p>air fuel mix again..check your timing also..</p><p>better go for ga16de efi lah..dlm 1500-2000 je engine tu..</p><p>beli half cut, jgn beli engine asing dgn wiring...</p><p>make sure u check any engine oil leak at gasket head when searcing for new engine.avoid this kind of engine...lagi headache in future. PLZ READ SUUNY MSG..LOTS GOOD INFO FOR U...</p></blockquote><p></p>
[QUOTE="WBW7827, post: 657486, member: 14685"] u can go to jalan kapar to find lots2 of ga16de efi..dunno auto or manual transmission.. about ur sudden accel press when switch on aircond then engine just died; i think somethin to do with vacum, or air fuel mix not tuned well..try tanya ur mechanic.. about black smoke; maybe ur piston rings dah worn out and air fuel mix again.. about hi fuel consumption; air fuel mix again..check your timing also.. better go for ga16de efi lah..dlm 1500-2000 je engine tu.. beli half cut, jgn beli engine asing dgn wiring... make sure u check any engine oil leak at gasket head when searcing for new engine.avoid this kind of engine...lagi headache in future. PLZ READ SUUNY MSG..LOTS GOOD INFO FOR U... [/QUOTE]
R35 Used Titanium Exhaust
Z Owners' List
Z Owners' List
Hey all! Just thought we should have a roll call for Z owners. List down all your precious Zs, pls. Do update the list.
- nick - name - model - year - color - reg. plate
Thanks!
1. Beautle (Anin) -...
Ssbc
Do anyone know how to wiring this thing to the car?
got 8 wire from the controller.
gear knob
i have a screw on type gear knob(hope u all know what i mean, heh heh)...
due to constant gear shifting, the gear knob will loosen after some time which i have to rescrew it back(very annoying)..
recently i found...
Car Brands
Car Manufacturers
Nissan
help my N13
