Main Forums
Interests
Do-It-Yourself Garage
Help me here...
<blockquote data-quote="gHetto_sPeed" data-source="post: 2761897" data-attributes="member: 23786"><p>Search Forums </p><p></p><p>Enter your search terms Submit search form </p><p>Zerotohundred.com Web </p><p></p><p></p><p></p><p></p><p>Show Threads Show Posts </p><p>Advanced Search </p><p></p><p>Quick Links </p><p>Today's Posts </p><p>Mark Forums Read </p><p>Open Buddy List </p><p>User Control Panel </p><p>Edit Signature </p><p>Edit Profile </p><p>Edit Options </p><p>Miscellaneous </p><p>Private Messages </p><p>Subscribed Threads </p><p>My Profile </p><p>Who's Online </p><p></p><p>Go to Page... </p><p></p><p></p><p></p><p></p><p></p><p>Zerotohundred.com Forums > Cars > Do-It-Yourself Garage </p><p>Help me here... </p><p></p><p></p><p></p><p></p><p>View First Unread LinkBack Thread Tools Search this Thread Rate Thread Display Modes </p><p></p><p>#1 (permalink) Yesterday, 11:34 AM /if> </p><p>gHetto_sPeed </p><p>Junior Member Join Date: Feb 2006</p><p>Location: SeLangor</p><p>Posts: 1 </p><p></p><p>Help me here... </p><p></p><p>--------------------------------------------------------------------------------</p><p></p><p>I'm using a 4g63t engine.I'm a little bit shy to admit this but i'm a newbie in this car stuff,since i'm a rempit earlier.</p><p>My car temperature meter suddenly boosted to 'santak'.tat means the temp is very high on the dashboard above the 'H' signs..and 'check engine' also appear on my dashboard.</p><p>What should I do?Pls help me...</p><p></p><p></p><p></p><p>gHetto_sPeed </p><p>View Public Profile </p><p>Send a private message to gHetto_sPeed </p><p>Send email to gHetto_sPeed </p><p>Find all posts by gHetto_sPeed </p><p>Add gHetto_sPeed to Your Buddy List </p><p></p><p>#2 (permalink) Yesterday, 12:08 PM /if> </p><p>BEan </p><p>Member Join Date: Oct 2004</p><p>Posts: 53 </p><p></p><p>Re: Help me here... </p><p></p><p>--------------------------------------------------------------------------------</p><p></p><p>the simplest answer is to send ur car to the mechanic.but if ur into diy stuff then here's what u need to do.chk if ur radiator has water in it or not.if no then try refilling it with water.if there's a leak in ur cooling system u should be able to see water leaking.find the source and fix it.chk ur radiator cap to see if its corroded or jammed.also chk ur thermostat if its rusted and jammed also.chk that the water pump is running or not.open the radiator cap and start the engine.be caution though not to open the radiator cap when the engine is hot.press the accelerator pedal slowly and chk to see the water in the radiator cap rises and swirls in the tank.if the water swirls mean ur pump is working.there should be small bubbles but if there's a huge amount of bubble,it could mean u have a leaking head gasket.next is to chk ur fan.run ur engine 4 a while and wait until the fan turn.if it doesn't chk ur fan motor and the fan relay.hope this helps.</p><p></p><p>But there's no leaking at the radiator.I've checked it thousand times already. If the wiring is the problem,can't help but to send to mechanic sajerr...Boco pale boh!Anyway,thanks guys!</p></blockquote><p></p>
[QUOTE="gHetto_sPeed, post: 2761897, member: 23786"] Search Forums Enter your search terms Submit search form Zerotohundred.com Web Show Threads Show Posts Advanced Search Quick Links Today's Posts Mark Forums Read Open Buddy List User Control Panel Edit Signature Edit Profile Edit Options Miscellaneous Private Messages Subscribed Threads My Profile Who's Online Go to Page... Zerotohundred.com Forums > Cars > Do-It-Yourself Garage Help me here... View First Unread LinkBack Thread Tools Search this Thread Rate Thread Display Modes #1 (permalink) Yesterday, 11:34 AM /if> gHetto_sPeed Junior Member Join Date: Feb 2006 Location: SeLangor Posts: 1 Help me here... -------------------------------------------------------------------------------- I'm using a 4g63t engine.I'm a little bit shy to admit this but i'm a newbie in this car stuff,since i'm a rempit earlier. My car temperature meter suddenly boosted to 'santak'.tat means the temp is very high on the dashboard above the 'H' signs..and 'check engine' also appear on my dashboard. What should I do?Pls help me... gHetto_sPeed View Public Profile Send a private message to gHetto_sPeed Send email to gHetto_sPeed Find all posts by gHetto_sPeed Add gHetto_sPeed to Your Buddy List #2 (permalink) Yesterday, 12:08 PM /if> BEan Member Join Date: Oct 2004 Posts: 53 Re: Help me here... -------------------------------------------------------------------------------- the simplest answer is to send ur car to the mechanic.but if ur into diy stuff then here's what u need to do.chk if ur radiator has water in it or not.if no then try refilling it with water.if there's a leak in ur cooling system u should be able to see water leaking.find the source and fix it.chk ur radiator cap to see if its corroded or jammed.also chk ur thermostat if its rusted and jammed also.chk that the water pump is running or not.open the radiator cap and start the engine.be caution though not to open the radiator cap when the engine is hot.press the accelerator pedal slowly and chk to see the water in the radiator cap rises and swirls in the tank.if the water swirls mean ur pump is working.there should be small bubbles but if there's a huge amount of bubble,it could mean u have a leaking head gasket.next is to chk ur fan.run ur engine 4 a while and wait until the fan turn.if it doesn't chk ur fan motor and the fan relay.hope this helps. But there's no leaking at the radiator.I've checked it thousand times already. If the wiring is the problem,can't help but to send to mechanic sajerr...Boco pale boh!Anyway,thanks guys! [/QUOTE]
R35 Used Titanium Exhaust
Izzit true bot will affect reliability? How severe will be affected actually?
I've browsed alot in zth. but alot mix answers. So my main question is :
If BOT low boost plus upgrading essential internal and parts if done professionally, just to increase the response of the car and not for...
Pirelli’s new F1 rubbers peak out
The curtains may have closed on the 2010 Formula One season but...
Hello there everyone
Hi, Alex here... ^^
I'm erm, rather taken by the 3rd gen RX-7, to put it mildly...and I'd like to learn more about the car, the engine and the concept of eevrything rotary-related.
Currently driving a Wira....but...
sn964444
Main Forums
Interests
Help me here...
