Car Brands
Car Manufacturers
Perodua
HELP!!! Kelisa can't start!!
<blockquote data-quote="lek9925" data-source="post: 1063975926" data-attributes="member: 42001"><p>i had changed the map sensor, cam shaft sensor and swapped ECU, but the car still unable to start.</p><p></p><p>Any professional is available to help?</p><p></p><p>will the alarm system cut off the ignition coil? no spark while engine is cranking!</p><p></p><p>Please kindly advice and your help is greatly appreciated!</p></blockquote><p></p>
[QUOTE="lek9925, post: 1063975926, member: 42001"] i had changed the map sensor, cam shaft sensor and swapped ECU, but the car still unable to start. Any professional is available to help? will the alarm system cut off the ignition coil? no spark while engine is cranking! Please kindly advice and your help is greatly appreciated! [/QUOTE]
need help on tyre price
i want to compare the price between tyre size:
1. 205/45R17
2. 205/50R17
my question is which of the tyre more expensive is same brand?
help needed
hi i just asking can any1 tell me webber is a good idea or not and who can pasang if i buy it?
sard trigger need HELP
having problem on the solenoid part, there state in and out, which is where to in and where to out?
and any english manual available there?
Car Brands
Car Manufacturers
Perodua
