Main Forums
Interests
Do-It-Yourself Garage
HELP: How to remove Clarion HU
<blockquote data-quote="cacin" data-source="post: 844884" data-attributes="member: 10222"><p>do you see any hole if you remove the faceplate?</p><p>Maybe you can remove the HU from there.</p><p>At the edge of each corner (when the faceplate is removed), there would be a hole where you can insert a (4 actually) pins to pull the HU out. The normal way that I know is once you inserted the pins, pull it outwards (all 4) before pulling the HU out.</p><p></p><p>Hope this helps.</p></blockquote><p></p>
[QUOTE="cacin, post: 844884, member: 10222"] do you see any hole if you remove the faceplate? Maybe you can remove the HU from there. At the edge of each corner (when the faceplate is removed), there would be a hole where you can insert a (4 actually) pins to pull the HU out. The normal way that I know is once you inserted the pins, pull it outwards (all 4) before pulling the HU out. Hope this helps. [/QUOTE]
david tao
Lancer GT mod advice
I'm currently planning to mod my gt. I'm looking at;:hmmmm:
1. convert bodykit - stock to evoX
2. change muffler - stock to twin muffler
3. tune or change suspension
4. change braking system
I'll be doing them 1...
diy silver gear console box for proton waja
http://lochangyong818.fotopic.net/
Relay Wiring
hello all sifu thanks for viewing this thread, i have the fog lights done and its working fine with my current setup, which is a direct +ve and -ve wire from batery to a fuse then to a swtich then to the fog lights...
Main Forums
Interests
