Main Forums
Interests
Do-It-Yourself Garage
[help]How to install Power Cap?
<blockquote data-quote="yewnen" data-source="post: 915572" data-attributes="member: 17444"><p>So the AC terminal is connected to remote turn on from HU? if confirm, then i'll connected the remote to to trigger the relay to connect the battery voltage to AC terminal. OK?</p></blockquote><p></p>
[QUOTE="yewnen, post: 915572, member: 17444"] So the AC terminal is connected to remote turn on from HU? if confirm, then i'll connected the remote to to trigger the relay to connect the battery voltage to AC terminal. OK? [/QUOTE]
david tao
Best Security for Evo
Harlo... dear evo sifu here..
May i know wat is the best Alarm system for an Evo, since my 8 Chai is coming soon, so need some idea from everyone.
Izzit Capter really help or wats alarm should i go for?
anothe is...
check it out for evo owner
check this out
nice rim
http://www.zerotohundred.com/newforums/chassis-and-wheels/197503-kosei-17-a.html#post2666208
Block Suggestion
Hi people of ZTH,
Had some problem ,
My crankshaft bearing was eaten up and further ate my block
now i have two choices
- buy new block
- weld the eaten up place in machine shop and touch up with new bearing
What do...
Main Forums
Interests
