Main Forums
General Talk
Help Help>> Kenari Check Engine light ON
<blockquote data-quote="huakenny" data-source="post: 947614" data-attributes="member: 9770"><p>wa...'reset ecu' tis topic owes discuss in forum la....search then u wil know...but i tel u now la...if u lazy search</p><p></p><p>disconect negative side battery terminal, leave it for 45minutes.....then before u put it back..press ur brake for few times(no harm try tis if useless)..then put back the batery terminal...</p><p></p><p>start ur car n test-drive it...ecu wil relearn ur new driving style again.....cheers</p><p></p><p>*some take it out and put it back for 5minutes only...but i not sure whether it is reset oledi..so juz leave it longer time..safer....hehe</p><p></p><p><img src="https://zerotohundred.com/forums/styles/default/xenforo/smilies/tee.gif" class="smilie" loading="lazy" alt=":tee:" title="Tee :tee:" data-shortname=":tee:" /></p></blockquote><p></p>
[QUOTE="huakenny, post: 947614, member: 9770"] wa...'reset ecu' tis topic owes discuss in forum la....search then u wil know...but i tel u now la...if u lazy search disconect negative side battery terminal, leave it for 45minutes.....then before u put it back..press ur brake for few times(no harm try tis if useless)..then put back the batery terminal... start ur car n test-drive it...ecu wil relearn ur new driving style again.....cheers *some take it out and put it back for 5minutes only...but i not sure whether it is reset oledi..so juz leave it longer time..safer....hehe :tee: [/QUOTE]
Pcd?
jst wondering... is pcd 114 same as 114.3??? are ppl rounding up the figure from 114.3 to 114???
Lotus Evora now on sale in Malaysia
https://www.zerotohundred.com/wp-content/uploads/2010/06/Lotus-Evora-Malaysian-Launch-6-600x398.jpg
The highly acclaimed Lotus Evora is finally here in Malaysia. Launched in 2008 at the British International...
Side Fender Kancil
how do i take off side fender kancil is it got 2 nuts?
then after removing got lots wires or not from it cause side have signal.
reason want to knock back fender dent . thanks gang
Main Forums
General Talk
