if fully close,around 2-3mm.
So bro, does it hv better torque if fully/partially close?
Even using big diameter straight flow muffler the sound will be controlled well?
yup...usually vtec kaki in the state like to use this set up.for race mode,they close the valve tolike vtec..... kekekekeke
yup...still avail.theoretically yes.and the product is still available?? so even i use bigger diameter piping also wont decrease torque since i can adjust the valve half closed?
Normally there are 2 source of leaking from them. The rubber surrounding the door loose or damage liao OR most likely the water proof plastic sheet inside the door got holes or not...
