Main Forums
General Talk
Heat wrap.
<blockquote data-quote="whatdamn" data-source="post: 772473" data-attributes="member: 5381"><p>140dB,</p><p>are you reffering mainly to turbo applications? because in that case my statement is mute cause for turbo/supercharged applications, yes, the exhaust manifolds would experience extreme heat due to extreme conditions that come with forced induction. anyway, i remember someone telling me that you can't wrap stainless steel extractors or else it'll crack, so you should only wrap glavanized steel ones. how far is this true?</p><p></p><p>dino,</p><p>ey, explain in detail la, you've got a brilliant thermo lecturer last sem correct? ahha, so pls prof, explain :D</p></blockquote><p></p>
[QUOTE="whatdamn, post: 772473, member: 5381"] 140dB, are you reffering mainly to turbo applications? because in that case my statement is mute cause for turbo/supercharged applications, yes, the exhaust manifolds would experience extreme heat due to extreme conditions that come with forced induction. anyway, i remember someone telling me that you can't wrap stainless steel extractors or else it'll crack, so you should only wrap glavanized steel ones. how far is this true? dino, ey, explain in detail la, you've got a brilliant thermo lecturer last sem correct? ahha, so pls prof, explain :D [/QUOTE]
R35 Used Titanium Exhaust
outside workshop or subaru HQ is better -subaru owner
I have accident with driving my new subaru xv, need to re-painting, change bumper, change the rear lower arm. please advice me , is that send back to subaru hq or outside workshop , which one is better? Please advice...
Used TRD Monoblock Caliper and Disc Rotor For sell
MONOBLOCK HIGH PERFORMANCE BRAKE KIT
PCD 114.3 / Disc rotor 323mm, been used 12000km
An aluminum monoblock caliper takes this high-performance brake kit to an even higher level...
Reasons why you like ur MR
:_:
Just to know what everyone feels about their ride.
AW11, SW20, ZZW30 everyone welcome
Just need to state version of your MR and reasons why you like it so much.
Main Forums
General Talk
Heat wrap.
