Car Brands
Car Manufacturers
Daihatsu
HC-E for Charade....
<blockquote data-quote="ceretspoon" data-source="post: 452198" data-attributes="member: 7046"><p>Actually u take the block of the 1.6 not the head....this because the deto combustion head is slightly bigger than 1.3...if u put the 1.6 head into a 1.3 engine...u'll get a low compression. If u put a 1.6 block into a 1.3 than u'll get a high compression engine. </p><p>It other way..its like the Vtec b16 with a b20 block....by the way to make things greater...use the HC piston rather than the HD coz HC piston is much more dome. Higher the compression is good for NA cars....just remember to tune it well....</p></blockquote><p></p>
[QUOTE="ceretspoon, post: 452198, member: 7046"] Actually u take the block of the 1.6 not the head....this because the deto combustion head is slightly bigger than 1.3...if u put the 1.6 head into a 1.3 engine...u'll get a low compression. If u put a 1.6 block into a 1.3 than u'll get a high compression engine. It other way..its like the Vtec b16 with a b20 block....by the way to make things greater...use the HC piston rather than the HD coz HC piston is much more dome. Higher the compression is good for NA cars....just remember to tune it well.... [/QUOTE]
jeff6126
Honda Jazz FLRS side skirt
jeff6126
yellowcaliper /caliperspray
jeff6126
Te37 Track Edition 2 FK8 FL8 Civic Type R Rim Wheel...
Revozport R35 GT Wing Spoiler and Trunk
original rare Work Emotion 11R 18x8.5jj offset +47...
david tao
Spoon FK8 FL5 19 inch rim wheel Type R
Litchfield GTR R35 Road Suspension Kit Absorber
original rare Yokohama ADVAN Racing RG3 18x8.5jj...
david tao
~accident repair ~touch up paint
jeff6126
Looking for 808 or mazda coupe
Hi looking for legal mazda 808 coupe or other mazda coupe. With or without restored. Kindly msg me ASAP. Thanks guys
Help Needed...Cant cure my Evo3 engine..
bro sifus and masters of 4G63,
my engine timing belt putus so i rebuild another engine...
diesel 2.2 blok with 1jz piston (piston rings in good condition)...
replace head gasket with custom metal 1.8mm...
used endless 6 pot
hehehe.....used skyline 6 pot endless for sale with rotor (size 350mm) and SSS brake pads...
asking for Rm8888.00 price still can be nego...
pic wil update soon
wish u all a very happy chinese new year:X-: :X-: :X-:
Car Brands
Car Manufacturers
Daihatsu
