Hardrace suspension & chasis
SuperVelocity
5,000 RPM
HardRace Suspension & Chasis Products Available for HONDA/NISSAN/SUBARU/BMW/MAZDA/TOYOTA/MITSUBISHI
Upgrade Suspension (Camber Kits)
- Lower Control arm is made by high density steel.
- Collocation with hardened rubber bushing (street racing) or anti-dust pillow ball bushing (drifting).
- Provide advanced stability during high speed driving or hard cornering.
- Immediately response from driver's steering control under acceleration.
- Adjustable links are assembled with WAVE WASHERS between nuts and bolts, which enable both of them can tight more harder, won't come loosen or back off.
- In additional, WAVE WASHERS allow many times loosen and tighten again, unlike competitor's products are difficult to loosen or tighten while doing the next alignment in the future.
Reinforced Engine Mounts
- Hardness rubber mounts creates more strength than OE rubber mounts.
- Immediately experience the feedback from engine acceleration.
- Reduce engine movement significantly.
- Provide the maximum output under engine acceleration.
- Compoung with high anti-vibration and durometer rubber material.
bro, do u have this for suzuki swift sport? item 6623.
http://www.hardrace.com/products.asp?strClass1=10&strClass2=43
Hi there,kindly pm me the best price for Rear Adjustable Camber kit for EG4drs pls
Thank you very much:wavey::wavey::wavey:
