Main Forums
Car Talk
Car Modification
gsr and gsr rs
<blockquote data-quote="gooseman" data-source="post: 628811" data-attributes="member: 6357"><p>A friend of mine has a RS in his wira... </p><p></p><p>Came with...</p><p></p><p>normal GSR ic</p><p>downpipe</p><p>same hp with normal GSR</p><p>manual ac</p><p></p><p>The RS is just a lighter version of the lancer 1.8 turbo... maybe with a stiffer and stronger chassis.... kinda like satria GTI R3... same engine less everything else and lighter....</p></blockquote><p></p>
[QUOTE="gooseman, post: 628811, member: 6357"] A friend of mine has a RS in his wira... Came with... normal GSR ic downpipe same hp with normal GSR manual ac The RS is just a lighter version of the lancer 1.8 turbo... maybe with a stiffer and stronger chassis.... kinda like satria GTI R3... same engine less everything else and lighter.... [/QUOTE]
[WTS] Autronic SM2 (used)
1 unit Autronic SM2 for sale. Used item.
Only ECU available, harness, wiring and everything else have to be purchased yourself.
RM6000
email:
[email protected]
Road tax question
How much do you pay for the road tax for owning an RX-7 ? Is there any difference between FC3S and FD3S ? I'm not sure but hope some one can provide me with an inkling of the cost... :rolleyes:
I'm still a rotary...
trust wastegate(thai)
how can i set to lower the boost? izzit with the alan key above, if yes i tight it to make it lower boost or loose it?
ae92joon
Main Forums
Car Talk
Car Modification
gsr and gsr rs
