Greddy T67-25G turbo
cmng
3,000 RPM
Anyone here have detail on this turbo
Greddy T67-25G turbo 8cm or 10cm housing
Boosting efficiency level and HP rated
HP rated on 2.0 car . Evo or SR also can
since want to see the turbo flow diagram
as well Greddy turbo is rebuildable ?
google around but not much dyno chart available to review
TQ
TQ
wow,sifu cmng, long time quiet :)
anyways, only thing i know is
Compressor Inducer size is 60mm, exducer is 78mm
Hp range :
Compressor map, huhuhu, will try looking for one
T67 actually has a TD06 turbine wheel , and a TD07 compressor wheel ,
so if we find a td07 compressor map , it should be the same
apa sifu sifu.. student ada la.. still learning la
i checked the spec as well
but wondering it worth while to upgrade on it
that why i want to see dyno chart on a 2.0 car to see laggy or not since not sure whether change from existing GT3071R to T67-25G
Thank Jinkl
mostly Evo boy a lot using Greddy kit but most of the complain is those 10cm turbine housing
which is consider laggy
the one i have is 8cm
T67-25g with 8cm turbine housing can produced power up to 475whp depend on setting & internal. I'm used this b4 on my 4G63 evo3...very nice turbo & now I'm upgrade to Garrett GT 40 to another power...
