Car Brands
Car Manufacturers
Toyota
fuel regulator
<blockquote data-quote="EFN" data-source="post: 986019" data-attributes="member: 1416"><p>4A-GE 20V is NOT a friendly uncle like motor. Cold start will always be running as high as 2000RPM on Auto Choke. And please remember that from the very beginning 4A-GE is designed to be a HIGH REV motor which could withstand substantial heat - this means that the engine itself will heat up for quite a while initially. And STANDARD idle range for 4A-GE is definitely at around 850 to 950RPM, sometimes even 1000RPM - WHICH IS ABSOLUTELY NORMAL.</p><p></p><p>Drink Fuel? You have not even tell us how may KMs your 20V goes, or even Auto or Manual. Most 4A-GE can only go at around 350Kms on RM50 (30L) worth of fuel (RON97). if this is too much for you maybe you have to consider using 4A-FE back, comprende? hahahahaha</p></blockquote><p></p>
[QUOTE="EFN, post: 986019, member: 1416"] 4A-GE 20V is NOT a friendly uncle like motor. Cold start will always be running as high as 2000RPM on Auto Choke. And please remember that from the very beginning 4A-GE is designed to be a HIGH REV motor which could withstand substantial heat - this means that the engine itself will heat up for quite a while initially. And STANDARD idle range for 4A-GE is definitely at around 850 to 950RPM, sometimes even 1000RPM - WHICH IS ABSOLUTELY NORMAL. Drink Fuel? You have not even tell us how may KMs your 20V goes, or even Auto or Manual. Most 4A-GE can only go at around 350Kms on RM50 (30L) worth of fuel (RON97). if this is too much for you maybe you have to consider using 4A-FE back, comprende? hahahahaha [/QUOTE]
R35 Used Titanium Exhaust
EVO GTA RPM Drop
Hi Guys,
I'm new in this forum and perhaps sifu sifu here can give me some advise on my issue. I owned an evo 7.5 gta and lately getting a very strange problem which is the RPM drop tremendously to 500 and bounce...
Engine Cover Spray , Lettering emblem only
What u need
1 . your spray paint
2. masking tape
3. fire source
4. candle
5. hair dryer
Ok first melt candle on ur engine head where needed like this ...
The Malaysian Super Series RD1 2005
Malaysia’s top superbiker Lee Ching Hooi began his defence of the Malaysian Super Series title in grand style when he won the opening round of...
Car Brands
Car Manufacturers
Toyota
fuel regulator
