Main Forums
General Talk
fuel regulator save fuel
<blockquote data-quote="ABV9750" data-source="post: 1701922" data-attributes="member: 9375"><p>plain english please. ppl can't understand what you really mean.</p><p>you want to save fuel by adding a fuel regulator for what? this regulator is to regulate more to sustain the fuel pressure. Gti need more and more pressure during high revs.this is the benefits of fuel pressure regulator FPR.</p><p>if you want to get 100km/rm10, don't be heavy footer..drive below 2500rpm. gti fuel mapping start twice from 3000rpm and 6000rpm (cultus). thats why you can feel its powerband at this point.</p><p>to tune FPR, you must double set it during idle and moving..i can't remeber but you can check at manual. std pressure is 33-35psi and normally ppl increase to 40-42psi..this would give enough pressure during moving (approx. 22psi) BUT make sure your pump is good or otherwise, you might kill it.</p><p>for std. cultus, its sufficient amount.onli that in our case, potong condition, we must hav FPR to get the std pressure..</p></blockquote><p></p>
[QUOTE="ABV9750, post: 1701922, member: 9375"] plain english please. ppl can't understand what you really mean. you want to save fuel by adding a fuel regulator for what? this regulator is to regulate more to sustain the fuel pressure. Gti need more and more pressure during high revs.this is the benefits of fuel pressure regulator FPR. if you want to get 100km/rm10, don't be heavy footer..drive below 2500rpm. gti fuel mapping start twice from 3000rpm and 6000rpm (cultus). thats why you can feel its powerband at this point. to tune FPR, you must double set it during idle and moving..i can't remeber but you can check at manual. std pressure is 33-35psi and normally ppl increase to 40-42psi..this would give enough pressure during moving (approx. 22psi) BUT make sure your pump is good or otherwise, you might kill it. for std. cultus, its sufficient amount.onli that in our case, potong condition, we must hav FPR to get the std pressure.. [/QUOTE]
Blog by Director > How to Clean Bike's Chain and Crank ? Kartik Borikar
How to clean Bike's Chain and Crank ?
Be it Bikes or Bicycles, chain and cranks are common to both.
Chain and the crank get dirty as you use your cycle. The dirt which is basically sand / fine mud needs to cleaned...
Looking for FD engine kosong
Guys,
Looking for FD engine kosong for my personal use. Any offer, PM me your best price.
Cheers,
Jason
Ssqv Valve Diaphragms Replacement
hi guys..how much will it cost to get brand new valve diaphragms for my SSQV BOV?..any info pls..thanks
vr2turbo
Main Forums
General Talk
