Car Brands
Car Manufacturers
Toyota
fuel regulator leaking!!!
<blockquote data-quote="ayathu" data-source="post: 1063660303" data-attributes="member: 49498"><p>I agree, I got a works one, after a week got problem with regulator, it did not regulate it just fluctuate up and down, went back to shop and the diaphram was changed, but the gauge soo far soo good.<span style="color: Silver"></span></p><p><span style="color: Silver"></span></p><p><span style="color: Silver"><span style="font-size: 9px">---------- Post added at 09:04 AM ---------- 6 hour anti-bump limit - Previous post was at 09:01 AM ----------</span></span></p><p><span style="color: Silver"></span></p><p><span style="color: Silver"></span>Forgot to mention the Regulator was not fixed properly, teflon tape was blocking the air inlet.</p><p></p><p>That was the reason it failed. Sometime its not product quality is bad but the workmanship is bad<img src="https://zerotohundred.com/forums/styles/default/xenforo/smilies/banghead.gif" class="smilie" loading="lazy" alt=":banghead:" title="Banghead :banghead:" data-shortname=":banghead:" /></p></blockquote><p></p>
[QUOTE="ayathu, post: 1063660303, member: 49498"] I agree, I got a works one, after a week got problem with regulator, it did not regulate it just fluctuate up and down, went back to shop and the diaphram was changed, but the gauge soo far soo good.[COLOR="Silver"] [SIZE=1]---------- Post added at 09:04 AM ---------- 6 hour anti-bump limit - Previous post was at 09:01 AM ----------[/SIZE] [/COLOR]Forgot to mention the Regulator was not fixed properly, teflon tape was blocking the air inlet. That was the reason it failed. Sometime its not product quality is bad but the workmanship is bad:banghead: [/QUOTE]
looking for 300z gear box
looking for 300z gear box dont mind auto or manual
if manual,i need pedal n clutch pump
pliz call or sms fizal 012-3808045
RE Club TT @ Jaya One
Here are some shots.. more to come.. short of time..
http://www.autojunctions.com/images/stories/events/09/jan/re2/IMG_4191.jpg
http://www.autojunctions.com/images/stories/events/09/jan/re2/IMG_4192.jpg...
Need advise about my mirage turbo setup..
My 61t setup now....
TD04HL turbine
VR4 intercooler
2WD Mirage Turbo Gearbox
Evo Cam
Evo stock clutch and pressure cover (got it from evo halfcut)
1.5mm metal gasket
Adjustable campulley
Double diaphram fuel...
Car Brands
Car Manufacturers
Toyota
