Main Forums
Car Talk
Car Modification
Fuel Pump Question ~
<blockquote data-quote="upontheriversky" data-source="post: 1063727533" data-attributes="member: 59480"><p>the stock fuel rail has no return line so max pressure is pumped to the rail right? so i am confused as to how adjustable fuel regulator would help if i need more fuel pressure</p><p></p><p>and how would i know i need one?</p></blockquote><p></p>
[QUOTE="upontheriversky, post: 1063727533, member: 59480"] the stock fuel rail has no return line so max pressure is pumped to the rail right? so i am confused as to how adjustable fuel regulator would help if i need more fuel pressure and how would i know i need one? [/QUOTE]
VW CNY 2021 Discounts on Cars & Parts - Full List
Volkswagen Passenger Cars Malaysia is offering their Ang Pao rebates on their new VW cars, engine maintainence parts...
Exhaust Temp Meter
sifus, care to explain how to read the readings. All i know if the temp reach above 800'c the car running lean and will destroy the engine and the turbo. is it true?
Car jerks during boost
I've realised after installing larger injectors ie. 450cc to 510cc there are some jerks between 5000-7000rpm. May I know what are the likely causes ?
a ) too rich fuelling?
b ) sparks flooded?
c ) others...
Also in...
Main Forums
Car Talk
Car Modification
