Car Brands
Car Manufacturers
Daihatsu
fuel injection
<blockquote data-quote="raw_board" data-source="post: 1051608" data-attributes="member: 9888"><p>yups right...if u don't want use turbo engine but still wanna use the injection type,u can chose the L3 Opti enggine...660 injection..</p></blockquote><p></p>
[QUOTE="raw_board, post: 1051608, member: 9888"] yups right...if u don't want use turbo engine but still wanna use the injection type,u can chose the L3 Opti enggine...660 injection.. [/QUOTE]
jeff6126
Honda Jazz FLRS side skirt
jeff6126
yellowcaliper /caliperspray
jeff6126
Te37 Track Edition 2 FK8 FL8 Civic Type R Rim Wheel...
Revozport R35 GT Wing Spoiler and Trunk
original rare Work Emotion 11R 18x8.5jj offset +47...
david tao
Spoon FK8 FL5 19 inch rim wheel Type R
Litchfield GTR R35 Road Suspension Kit Absorber
original rare Yokohama ADVAN Racing RG3 18x8.5jj...
david tao
~accident repair ~touch up paint
jeff6126
RE Club Malaysia Meet up...
Ladies and Gentlemen....
Regardless you drive a FC, FD, SA, SE3P, or even any Toyota car powered by RE.... as long as you live Rotary, Sleep Rotary, Drink Rotary, Drive Rotary... listen up....
we'll be having an...
EVO I-III Ignition Timing
Does anyone have the stock ignition timing maps for EVO1/2/3 ?
Better still if you have dynoed and got the best timing for torque across rpm/load.
which Motul oil for evo..
hi guys,
Would like to know which MOTUL oil is suitable for evo engine, gear, ayc, acd, transfer case, differential n watever oil hv to change?
also can you pls note the quantity is needed for each change?
anyone...
Car Brands
Car Manufacturers
Daihatsu
fuel injection
