Car Brands
Car Manufacturers
Nissan
Fuel hose blues
<blockquote data-quote="wideawake" data-source="post: 780338" data-attributes="member: 388"><p>It has been a while since I installed a bosch 910 pump with a surge tank in the rear boot.</p><p></p><p>However, fuel smells in the car is a daily ordeal. The fuel hose in the engine bay leaked/burst twice already. The one in the rear burst twice also if I recall.</p><p></p><p>The stock line from the rear to the front is still the stock line, which I think is kinda small. I don't have an adjustable fuel regulator yet. And since I installed the new pump, I'm having idling problems. At traffic lights, when I slow down, the RPM will go down and die off.</p><p></p><p>I'm looking for a solution to change the whole fuel hose/line to something which is wider, and can resist higher pressure and heat. Anyone out there can suggest something? I'm sure you must have some kind off problem like this after you changed the fuel pump.</p><p></p><p>Thanks.</p></blockquote><p></p>
[QUOTE="wideawake, post: 780338, member: 388"] It has been a while since I installed a bosch 910 pump with a surge tank in the rear boot. However, fuel smells in the car is a daily ordeal. The fuel hose in the engine bay leaked/burst twice already. The one in the rear burst twice also if I recall. The stock line from the rear to the front is still the stock line, which I think is kinda small. I don't have an adjustable fuel regulator yet. And since I installed the new pump, I'm having idling problems. At traffic lights, when I slow down, the RPM will go down and die off. I'm looking for a solution to change the whole fuel hose/line to something which is wider, and can resist higher pressure and heat. Anyone out there can suggest something? I'm sure you must have some kind off problem like this after you changed the fuel pump. Thanks. [/QUOTE]
Aston Martin DB11 now in KL - SUPER potent 5.2L twin turbo V12, 600hp & 700Nm!
Aston Martin has unveiled its latest flagship grand tourer, the DB11 today. The unveiling of the car coincides with the...
RX8clubmalaysia Mega-Gathering 2009
We're at 78 RX8's joining this event... Just 22more RX8's to go.....And that is why I'm posting in ZTH in case there are RX8 owners here too.
Dunlop formula D01
Hi guys,
After did a few weeks model and price research. Finally I was decided to buy the Dunlop formula D01 as my 4 new tyres, the size is 205/50/16. At first I plan to buy Bridgestone or Toyo tyres, but...
Car Brands
Car Manufacturers
Nissan
Fuel hose blues
